08 f250 6.4 pulling a 07 jayco eagle 325bhs - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
 1Likes
  • 1 Post By Farmer Fred
post #1 of 7 Old 09-14-2013, 05:32 PM Thread Starter
Thinking about buying a used 2007 Jayco Eagle 325bhs fifth wheel. I'll be using my 2008 F250 6.4 4x4 Lariat with 20' wheels. Has anyone else used this setup or have any concerns with the setup? Thanks!
325BHS
Exterior Length 35'4"
Unloaded Vehicle Weight 9605
Dry Hitch Weight (lbs) 1825
Gross Vehicle Weight (lb... 12500
Cargo Carrying Capacity ... 2895
PeteyPipes is offline
post #2 of 7 Old 09-14-2013, 06:29 PM
toad's Avatar
Quoted: 16 Post(s)
That will be a piece of cake. I haul a 39 foot Teton that weighs just shy of 14k with my old 1996 7.3.
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #3 of 7 Old 09-19-2013, 03:26 AM
I have a Keystone Sprinter 311BHS which is pretty much identical in length and weight to the Jayco you're looking at. My '03 7.3 does pretty well with it. Hauled it from Baton Rouge to Birmingham earlier in the year.
Make sure you buy a really good weight distributing hitch setup. Have a good brake controller. Don't get in a hurry and don't expect to get good fuel mileage. I think I averaged around 10 mpg.
'03 F250 Lariat CC/SB FX4, 4R110 from FoMoCo, 6637 intake, AIH delete, aFe 4" straight, TS 6-pos, 38r on a blank pedestal, Iron Cross wheel-to-wheel steps, Recon smoked cab & 3rd brake light.
Rebel Horseman is offline
post #4 of 7 Old 11-09-2013, 09:58 PM
Cj Ford's Avatar
I just hauled a 40' jayco with my 99 7.3 no problem at all you have more than enough truck
I love my truck with pics
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #5 of 7 Old 11-19-2014, 11:09 AM
Farmer Fred's Avatar
I pull campers commercially with my truck, don't win any acceleration races with 3.55 gears. I stay at 2,025rpm in 4th gear at 55mph and get 10 to 12 mpg average. Got over 12 once with a 31" fifth wheel that had heavy duty F ply tires and that was a heavy camper, made me a believer in those commercial trailer tires help with fuel mileage. I have gone up every major hill in the Western part of the country and never ran out of power or felt that my truck was running to hot. I pull with my 450 tune. Been doing this for 60,000 miles so far this year.
2008 F250 CC SB 4x4 Lariat 6.4L 3.55 gears 2.5 Carli coils, Fox Shocks and 4" rear blocks 38x15.50R18 Toyos
ARP HS, All Deletes with wastegate, FASS 150 LP, Coolant Filter kit, S&B CAI, MBRP Intercooler Pipe, SCT tuner with 450 and 525 RWHP RCD tunes. 235,000 miles/ 5390 hours
2012 F250 CC SB 4x4 Lariat 6.7L 3.55 gears H&S Mini Maxx, DPF & EGR Deleted, S&B CAI 87,000 miles/ 2750 hours
Farmer Fred is offline
post #6 of 7 Old 11-19-2014, 11:25 AM
I should add that by running 55mph in 4th gear the EGTs stay in the 600 to 750 range were 5th gear running it will hang out around 900. Boost is in the 8 to 14 range in 4th and 5th gear it will be 20 or higher. IV played with speed and gears and I feel with my trucks gears that 55mph in 4th gear I get the best mileage, truck has awesome power and at the end of the day I'm less drained because the truck is riding smoother and not having to pass people all day long.
Olddudesrule likes this.
post #7 of 7 Old 12-10-2014, 11:03 AM
The camper is a 37' Montana and has a GWR of 16,960 pounds since it's new and empty I would guess it weighs 14,000 pounds but that I'd just my guess. I'm going from Indiana to Kelowna, B.C. 2,185 miles, nice camper.
ID:	365730   Click image for larger version
