First big haul. 3000 mile PCS. 14k # 24' bumper pull. 05 CCSB 6.0. Can I do it? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 23 Old 04-04-2013, 12:51 PM Thread Starter
onemeansaleen's Avatar
Been reading some of these posts and it's tough getting through the gooseneck & "big fish" posts.
I just got my first PowerStroke to move my household goods from AL to WA. I bought an 8.5x24 enclosed with dual 7000# axles. Question is will I be able to safely pull it if I happen to hit the max trailer weight of 14k#?
Truck is an 05 CCSB 6.0 diesel on a 6" lift with 35s. I do have a drop hitch to keep the trailer level @ 15".
Any advice you guys could give me would be appreciated. First big pull and it has me a little nervous. Anything I NEED to do? Different hitch? Bags?
Trying not to get too deep into more $$$. Have to save some cash for 6.0 upgrades.
Thanks in advance guys
2005 CCSB Lariat Fx4, 6" ProComp Lift, 35x12.5x18 Nitto Trail Grapplers on Dick Cepek DC1 Wheels, BPD oil cooler & EGR cooler, Sinister Diesel Coolant filter, 4" MBRP exhaust, Airaid CAI, Superchips tuner, plasti-dipped flares/rockers and grill, Hornblasters
train horn w/ OB compressor, Harley lights with HIDs, Kenwood DNX5190 touch screen DVD/GPS AND GRENADE VALVE STEM CAPS
onemeansaleen is offline
post #2 of 23 Old 04-04-2013, 12:57 PM
atvrider93's Avatar
Quoted: 8 Post(s)
As long as your hitch and everything is rated high enough. 14Klbs is a lot of weight to be toting around from a rear mounted hitch. Keep in mind that correctly distributed, that's leaving you with ~ 1400lbs of tongue weight. make sure that is within other ratings
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 23 Old 04-04-2013, 01:10 PM Thread Starter
Okay thanks. Do I need a weight distributing hitch? I've read some people say that's the only way a F250 was rated for 12,500#. Total newbie here but I'm assuming that would not be the one that came with the truck from Ford?
Only doing this pull once then it's just my show car in the back
post #4 of 23 Old 04-04-2013, 01:33 PM
The Silent Service
colo_dually's Avatar
Quoted: 15 Post(s)
First, since you've already purchased the trailer - get the weight distribution setup. First your hitch (if still stock- only one hitch came installed in the F250/F350SRW) is only rated to 8K without it (and 12.5K with W/D). So you are pushing the weight on a bumper level pull. Make sure your drop hitch (which you need as well) is rated to that weight.
I'd be more worried having everything within rating limits - which you are stretching with the F250 and that setup. 14K on a bumper pull, is a considerable load.
Any more specific questions, let me know.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 23 Old 04-04-2013, 02:32 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Good luck on your move!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #6 of 23 Old 04-04-2013, 03:28 PM Thread Starter
So here is what I've got. Looks like the B&W needs upgraded for sure. Not sure on the tow kit if I need to get a weight distribution kit to get to 12,500#. Looks that way from the sticker. Don't really want to spend $500-$900 on that if I don't have to. I know it will be under the GCVW and I'll pay attention to tongue weight and get that weighed before I roll out. What is the minimum I can get away with?
ID:	92546   Click image for larger version
post #7 of 23 Old 04-04-2013, 09:57 PM
I'm sure its the same for enclosed trailers but with boat trailers, manufacturers usually shoot for 10% of the trailer weight be the tongue weight. So for a 14k lbs load you would be looking at 1400 lbs on the tongue. Your hitch is rated for 500 lbs of tongue weight without a weight distribution hitch. I tow a boat from my bumper which is about 12,500 lbs without a weight distribution hitch. I added air lift bags for the rear and a new hitch rated for 15k lbs without a WD hitch. I don't have to much of a problem with sag in the rear but the bags help a lot to stiffen the rear suspension up, which really reduces the rear from bouncing when going across dips on the highway. With a heavy bumper tow those dips on a soft suspension can really get the rear end of your truck moving. A 6in lift is not going to help you much on towing. I'm assuming removes it would also remove air bags as being an option and possibly a WD Hitch. Not sure they make shanks that drop down low enough. Check out etrailers.com. I got a new curt hitch from them on sale for $250 with free shipping plus they have about anything you could need related to trailers and hitches.
2006 F250 King Ranch 6.0L - 2.5" Leveling Kit w/ 4" rear blocks, ARP Studs, EGR Delete, 4" TB MBPR Straight Exhaust, SCT Tuner w/ Quick Tricks, Innovative, and Gearhead tuning, Blue Spring Upgrade, Dieselsite Coolant Filter, ScanGuage II, Dyno-Tune EGT guage, High Idle, Custom Wood Steering Wheel, PAC Aux Input, Ipad Mount, 5% Tint all around w/ 50% Windsheild Tint
Timbo126 is offline
post #8 of 23 Old 04-17-2013, 06:19 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You want to get away with the MINIMUM????
Trailer Hitches - Reese
Weight Distribution - Reese
That's basically what you need to be legal.
Will your receiver break? Probably not, but what if it does? More likely is that you'll fishtail and screw lots of stuff up, flip, possibly die.
Don't chance it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 23 Old 04-23-2013, 09:39 AM
Don't chance it.
I agree with the point you're trying to make but the equipment links you show were bogus. You don't need a 2.5" receiver to get 14000, a regular 2" can do it. You can pretty much just skip the Reese line, it is overpriced. Go to etrailer and check out the Curt brand.
It is unsafe and illegal to tow 14000 with the factory setup as pictured and the goofy hitch. You need better equipment. I tow a 10,000 lb trailer without W/D hitch since I upgraded from the factory ford receiver to a curt one rated for 15000 without WDH.
3000 miles is a long ways. There will be mountains too.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #10 of 23 Old 04-23-2013, 06:38 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I just go to Reese cause it's easier, and I agree you can do 14k without a 2.5", and I thought it was weird they didn't offer it.
4R100, 2wd
330,000 + miles
jesilvas is offline
