Towing with O/D off? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 7 Old 04-04-2013, 08:18 AM Thread Starter
colt32's Avatar
Most ive been towing is flat bed with hay or stock trailer. Do I run it with od off on highway? Cause when I do its tacked out whe. Running 65-70.
colt32 is offline
post #2 of 7 Old 04-04-2013, 08:20 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
How much are pulling?
2000-7.3L is offline
post #3 of 7 Old 04-04-2013, 09:37 AM Thread Starter
colt32's Avatar
Prolly 5-8k with stock trailer. And 10-15k with loaded hay
colt32 is offline
post #4 of 7 Old 04-04-2013, 11:05 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
In an obs pulling a grade with the weight turn the od off, newer trucks have a tow haul mode, but if flat ground it's fine, but keep an eye on your egt's and "downshift" when necessary to get the boost back up
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 7 Old 05-04-2013, 04:00 PM
atwelve's Avatar
I was wondering the same thing, I tow 3 times a week my 8k lbs landscaping trailer with my 2004 f350 DRW 4x4. Flat land with a bridge every once in a while and never over 45mph but just bought a TT loaded at 6200 lbs fully loaded. Once I the highway do I need to run in tow mode? I have a edge insight to monitor my temps but don't want to screw up the transmission.
atwelve is offline
post #6 of 7 Old 05-04-2013, 04:43 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Tow haul is designed for heavy loads and to protect the trans. I'd run it all the time if I had it.
And tow haul is completely diff than OD off.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 7 Old 05-04-2013, 07:31 PM
JER-1's Avatar
Quoted: 17 Post(s)
I run mine tow haul all the time with camper, bass boat , it just holds the gears longer,but it's great for slowing down I can start down a steep grade at highway speed just touch the brake ,let off and tow haul will hold that speeed all the way down the hill, saves brakes and wear and tear on tranny shifting a bunch.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
