Controling EGT - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 5 Old 03-19-2013, 10:14 PM Thread Starter
westcoast6.0's Avatar
Controling EGT
Quick question on how to control EGT. I understand all the products to help keep them under control but what about while driving. I live in an area that has a few areas with 10% grade over a couple of miles. So my question would be how would you go about lowering your EGT while going up hill? And making sure they don't continue to climb. Hopefully I will be getting a 5th wheel and just want to be as prepared as I can. Thank you for any advise.
Erick
2005 White CCSB 4X4
MBRP 4" straight pipe
RiffRaff Boots
Updated metal CAC tube
S&B CAI
Zoodad
ARP Head Studs
BPD EGR Cooler
OEM Oil Cooler
BPD Water Pump
Barder Stage 2 turbo
6.4 Banjo Bolts
Blue Spring
Zerex ELC-1 Coolant
SCT X3
Tunes: SPD, SRL+, XTREME STREET
Rudy's Diesel Up-Pipes
westcoast6.0 is offline
post #2 of 5 Old 03-19-2013, 10:54 PM
sprksonu's Avatar
water/methanol injection
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 5 Old 03-19-2013, 11:06 PM Thread Starter
Ya I meant should you pull over and let the temps drop try and slow down drop into a lower gear maintaining speed or go up a gear lowering rpms. Sorry never really towed anything with weight before.
Erick
2005 White CCSB 4X4
RiffRaff Boots
S&B CAI
Zoodad
ARP Head Studs
BPD EGR Cooler
OEM Oil Cooler
BPD Water Pump
6.4 Banjo Bolts
Blue Spring
Zerex ELC-1 Coolant
SCT X3
post #4 of 5 Old 04-06-2013, 09:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You wanna keep boost up, so drop gear gain rpm, and keep boost elevated, low boost will Kause high egt, and you going to slow down climbing that grade anyway
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 5 Old 04-06-2013, 11:29 AM Thread Starter
Thank you thats the kind of info I was looking for.
Erick
2005 White CCSB 4X4
RiffRaff Boots
S&B CAI
Zoodad
ARP Head Studs
BPD EGR Cooler
OEM Oil Cooler
BPD Water Pump
6.4 Banjo Bolts
Blue Spring
Zerex ELC-1 Coolant
SCT X3
