Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
Old 01-15-2008, 06:21 AM
bullfrog7286 bullfrog7286 is offline
I wanna tow a Gooseneck.
I wanna run a gooseneck with my f-250. But some people say that i cant do it bc of the lift and bigger tires that i have on my truck. I have 6 inchs of lift with 37s. Anybody have some advice?
Old 01-15-2008, 06:22 AM
GETERDID GETERDID is offline
lift on the trailer
Old 01-15-2008, 06:27 AM
Brian Brian is offline
you could tow a gooseneck, but you wont be able to get the weight on it like you could with e load tires and stock height.
Old 01-15-2008, 06:32 AM
What about tight turns and different angles of my truck and the trailer hitting my bed?
Old 01-15-2008, 06:36 AM
720Deere 720Deere is offline
You will pretty much need a custom built trailer to accomodate 6" of lift and 37s. My stock F350 SRW w/34" tires only has about 4" extra room before it would not be safe. You are talking about a truck that sits at least 7.5" taller than that.
It could be done but the front of the trailer would be too high and you could not haul much weight because of the trailer axle loading.
Tree Killer Tree Killer is offline
A adjustable neck on the trailer helps, My bro has a 6" lift a tows a gooseneck. You migtht need to pay more attn. to clearence between bed and trailer. it can be done though.
Old 01-15-2008, 06:38 AM
kinghawg98 kinghawg98 is offline
what if you have E range 37" tires?
I have a similar situation that might pop up in the next 2 yrs...would be nice to be "prepared"
Old 01-15-2008, 06:40 AM
im not sure if anyone makes 'e' load tires that big.
Old 01-15-2008, 09:06 AM
rednekexprez rednekexprez is offline
"Bear"
You would have to get a trailer with a tall neck..most have a shorter neck but some of the heavyduty with deck on the neck have taller necks...You could run Drange tires just watch running extra heavy loads for long distance at hiway speeds...
Old 01-15-2008, 09:47 AM
BigGreen06 BigGreen06 is offline
<b>Premium Member</b>
Just curious what size rims do you have?
-BG06.
