OD on or off for "light" load? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 2 Old 03-10-2013, 05:56 AM Thread Starter
I have a 1996 f250 7.3 Club Cab:
We'd like to get a popup tent trailer. So when checking the manual, as far as I could decipher, it said to leave OD on when towing, which is contrary to what I have known when I had Suburbans and towed a popup camper. We always pushed the little button taking it out of OD mode. Anyway, a popup is nothing for a 7.3 (3500 lbs or so) so I just leave the OD button on the end of the shifter alone and tow away?
Any help appreciated.
Rancho5 is offline
post #2 of 2 Old 03-10-2013, 07:30 AM
Slimline's Avatar
Leave overdrive on unless you find the transmission hunting for gears and shifting in and out of overdrive so to speak. For instance on long flats overdrive is good, in up and down hilly terrain it is probably better to lock it out unless its not causing the above mentioned hunting. A transmission temperature gauge is always a wise investment to help have an idea whats going on.
Happy towing!
1997 f250 extended can SRW 4x4 7.3 turbo, e4od (mildly built up)
DP Tuner F6 tuned by Jody
Rosewood stage 2 180/80 injectors
Diy intercooled
efuel conversion
t500 hpop ordered, waiting on delivery!
BHAF
4" straight pipe
Swamps IDM
Glowshift pyro, boost, tranny temp and fuel pressure gauges
AIC mod
Diesel site coolant filter
2" body lift and 35" Wrangler Dura Trac's
For Sale: E4od "Punisher" valvebody $150 obo
Slimline is offline
