trailer wiring troubleshooting - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 7 Old 03-08-2013, 11:03 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
We have a flatbed double axle trailer with electric brakes and 7 pin plug that we are trying to get the lights to work. when it is hooked up to my 99 f250 the brakes work and running, blinkers, and hazards work. but when the brake is pressed all of the trailer lights go out completely and turn back on when i let off the brake.
We also have a 07 cummins ram 3500 when it is hooked up none of the lights work at all. brakes work but no lights. we hooked the truck up to a 4 pin trailer with an adapter to the 7 pin and all lights work correctly and i even double checked the wiring at the truck with a volt meter. Next we hooked up the flatbed double axle trailer back up to the dodge and plugged the 7 pin connector in AND a seperate set of 4 pin tow light kit. Everything worked, the trailer lights, the seperate tow lights, and the brakes, but when the brakes were pressed the trailer lights would go out just like my ford. when the 4 pin tow lights were unplugged the trailer lights went out again.
wires we have on the trailer: BROWN (running lights) GREEN (right blinker) YELLOW (left blinker), there are no BLUE or WHITE wires on the trailer. the trailer brakes have a RED wire and BLACK wire going to them. from what i can tell the trailer grounds thru the hitch.
*Bought March 2011 @ 150K / Sold March 2016 @ 230K* E1999 7.3 PS 6 Speed,TS 6 position chip. K&N CAI, 4" straightpipe, Auto Meter Elite gauges.
*Bought May 2016 @ 59K* 07 F250 HD Edition 6.0 Stock
shordinges is offline
post #2 of 7 Old 03-08-2013, 11:24 PM
KAKnight's Avatar
I would start by grounding the trailer with a wire, never liked having them grounded threw the ball. But I would check and make sure none of the wires are exposed and touching the metal of the trailer and make sure they're not pinched together anywhere. Sounds like a short to me.
Sent from AutoGuide.com App
KAKnight is offline
post #3 of 7 Old 03-09-2013, 07:08 AM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
ok, im going to walmart to pick up an entire new trailer harness and install new wires. the old ones are ancient. i will also add a ground wire to the trailer and plug so we dont have grounding issues anymore.
post #4 of 7 Old 03-09-2013, 07:30 AM
jesilvas's Avatar
Quoted: 2 Post(s)
The way a 7way should be wired is
Black - 12V
White - Ground
Blue - brakes
Red - L turn
Brown - R turn
Green - running lights
Yellow - reverse
And yes I know brown and green are reversed from a 4way, but that's how it is.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 7 Old 03-09-2013, 01:08 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
we installed all new wiring and lights to the trailer and added a ground (white) wire and everything is brighter than before and works perfectly. i think the ground wire helped a lot. and the issues i was having with the brakes were the colors of the wires. i did not have a BLUE wire like i am supposed to. my brakes had a red and black wire. what i ended up doing was ground the black wire and plug the red wire in the blue slot for the brakes. took it for a test drive and the brakes work great. thanks KAKnight
post #6 of 7 Old 03-09-2013, 08:41 PM
KAKnight's Avatar
Glade you got it fingered out
Now your trailer lights won't flicker going down the road due to poor grounding through the ball
KAKnight is offline
post #7 of 7 Old 03-09-2013, 09:25 PM
StarDriver's Avatar
Sounds like with no ground, when you hit the brakes, it was pulling enough juice to kill the lights.
Glad you got it fixed.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
