Anyone able to help identify a hidden hitch tow capacity? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 3 Old 03-04-2013, 05:58 PM Thread Starter
Slimline's Avatar
Hey guys I am in a pickle. I would really prefer not to buy another hitch if I dont have to. I will be towing between 7-8000 pounds this summer, and wanted to ensure my hitch was capable. I bought a proper ball mount rated for the job, however the sticker on my hitch is worn right off and is illegible. It is a Hidden hitch brand, it appears rather beefy to me, it extends 20" along the frame rails and is all 1/4" plate. I have some pictures to compare to, I am hoping someone else has the hitch with the sticker still in tact. My f150 has the identical hidden hitch on it, which worries me that it may only be rated 500/5000. I dont plan on running a WD hitch. All the other class 3's are much shorter than mine and dont appear as beefy in pictures though.
By looks, I would say it appears class iv rated, but looks dont make me sleep better. I may have to just swallow the 250 bucks and buy one. I have searched the net far and wide trying to find this specific hitch by looks alone, as well as using kijiji etc looking for used ones. I assume it is a discontinued model. The only other hitch with a similar safety chain/wiring plate has a angled main tube, mine is straight across. It is all welded and bolted with 3 large bolts (unsure of grade) with large washers.
The pictures are from my f150 hitch (its the same) as without the gas tank and box in the way, its easier to obtain pictures.
*edited for better clarity**
ID:	77210   Click image for larger version
ID:	77218   Click image for larger version
ID:	77226   Click image for larger version
1997 f250 extended can SRW 4x4 7.3 turbo, e4od (mildly built up)
DP Tuner F6 tuned by Jody
Rosewood stage 2 180/80 injectors
Diy intercooled
efuel conversion
t500 hpop ordered, waiting on delivery!
BHAF
4" straight pipe
Swamps IDM
Glowshift pyro, boost, tranny temp and fuel pressure gauges
AIC mod
Diesel site coolant filter
2" body lift and 35" Wrangler Dura Trac's
For Sale: E4od "Punisher" valvebody $150 obo
Slimline is offline
post #2 of 3 Old 03-04-2013, 06:17 PM
jesilvas's Avatar
Quoted: 3 Post(s)
You say it's the same, but it still may be rated differently.
To be safe, I'd guess it's a ClassIII at 500/5000 like you said. Or 10000/10000 with WD hitch.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 3 Old 03-04-2013, 07:21 PM Thread Starter
Slimline's Avatar
Thats what I am figuring. I tried contacting hidden hitch, and they were just about as useless as one could imagine. I am going to try to do some more digging. I may have to bite the bullet and buy a new one. It is just going to make me angry bolting a new class 4 or 5 on there and seeing it look near identical with lengths and sizing or possibly less. A lot of the class 4 bars, the only difference I can notice is they have another small plate welded to the top of the receiver tube.
Diy intercooled
efuel conversion
BHAF
4" straight pipe
Swamps IDM
AIC mod
Slimline is offline
