trailer tire/rim load range question - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 8 Old 12-18-2012, 04:57 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
hello,
I just purchased a 21,000 triple axle gooseneck trailer. I got it on the cheap from an ol farm boy. Anywas, they only used it on the farm and the tires are in really rough shape, so they need replacing.
The rims all have 80 psi stamped near the valve stems.
As long as I get "LT" tires in Load Range E I should be good to go correct?
There was one tire on there that was a load range F
thanks for the help
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
MBRP up pipe assembly
4" MBRP Turbo back (straight piped) WHISTLE
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
post #2 of 8 Old 12-24-2012, 03:20 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Well, what is the GVWR of the trailer? What are the GAWRs?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 12-25-2012, 07:39 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
21,000 is what is stamped on the trailer.
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #4 of 8 Old 12-25-2012, 08:38 AM
StarDriver's Avatar
Are they 16" or 16.5", if they're 16.5, you'll want to get different rims, you can't hardly find those tires anymore.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #5 of 8 Old 12-26-2012, 05:57 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
they be 16"
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #6 of 8 Old 12-29-2012, 05:47 AM
StarDriver's Avatar
Here's a hint, go buy your tires from Discount Tire, get the certificates.
post #7 of 8 Old 12-29-2012, 10:04 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
ok what i've learned:
make sure the tires you buy are rated for the load capacity of the vehicle or trailer. So for instance since my trailer is 21,000 lbs gross. My 6 tires each need a minimum single axle load capacity at 3500 lbs. Now the tires need to be "LT" or "SP" in order to achieve the full rated capacity. Passenger car tires or light duty tires are not allowed to be used at 100% load capacity. This is why almost all trailer tires are "SP" (special) or use "LT" which comes standard on heavy duty trucks.
Ok so lets say you found a tire that is rated for 3500 lbs, now you have to look at "PSI" the tire has to be at to obtain that load rating. Some tires say 80 psi for a max load of 3500lbs single axle. But some say 100psi for a max load of 3500lbs single axle. Therefore, whatever rims you put the tires on have to be rated for that psi. All rims will have a psi rating stamped on either the back or front. Quality rims will have the stamped marking at or near the valve stem.
Ok so now lets say you have a trailer that has 4 wheels per axle, as opposed to just 2. The load rating for the tire is different. Most of the time the tire will have a stamping on their for single and dual wheel. The dual wheel max load rating is always less than the single. This is due to the fact that the tire manufacturer takes into account spacing between the tires so rocks and small children don't get stuck. Therefore, you have to make sure you use the lower max load rating.
wow, my brain hurts. P.S. all of this information can be obtained from tirerack.com in the technical section.
I suggest you do your OWN research rather than rely on a tire shop, they just want to make the sale and get the next customer thru. The DOT will not care where or who installed the tires, if your stuff aint up to snuff, guess what, your paying the ticket not Discount tire.
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #8 of 8 Old 12-29-2012, 10:09 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
TireRack.com - About - Tech Center
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
