Fifthwheel hitch weight distribution - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 24 Old 04-20-2012, 11:25 AM Thread Starter
Glow Plugs Only
dee004's Avatar
Today I ran by the local gravel yard and had them weigh my 05 F250 CCSB 4X4. He gave me the total weight of 3700KG (8140LBS), rear axle 1520KG (3340LBS) and front axle 2180KG (4796LBS). Only thing missing is the hitch (335LBS) is not in the truck at the moment. Once the trailer is attached and say the pin weight is 1800 LBS. Does anybody know from past experience how much of that 1800 LBS is seen by the rear axle and how much is shared by the front axle approximately? The bulk would be on the rear but there must be a percentage of the 1800LBS that is transferred to the front axle. Looking to buy a new fifthwheel but don't want to overload the rear axle or go over the GVWR or the CGVWR.
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #2 of 24 Old 04-20-2012, 11:39 AM
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
Hmmm. Good question. I've never thought about that. I know the hitch point of the 5er hitch sits just forward of the axle in order to keep 'some' weight up front.
You might try Googling it. With as long as people have been RVing, there's got to be some information out there. Now you have me curious.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 24 Old 04-20-2012, 11:44 AM Thread Starter
Glow Plugs Only
dee004's Avatar
Yes mine sits about 1 1/2" ahead of the centre of the rear axle, so a portion of the weight has to go forward. But I'm no physicist or P-Eng.
dee004 is offline
post #4 of 24 Old 04-20-2012, 12:10 PM
The increase in weight in each axle is proportional to the location of the center of the pin to the axles.
For example, on a 156" wheelbase (WB) if the center of the pin is 15.6" in front of the rear axle 90% of the weight will be on the rear and 10% on the front.
Assuming the pin offset (PO) is in front of the rear axle the base equation for rear is:
((WB - PO) / WB) * Pin Weight
The front axle would be:
Pin Weight - above answer
Not trying to be a KIA...lol. hope it helps.
azc9a7 is offline
post #5 of 24 Old 04-20-2012, 12:24 PM
Quoted: 304 Post(s)
Garage
Okay so if I'm understanding correctly (I've been known to be slow of the uptake):
Your formula would say:
156" (Wheel base) - 1.5" (Pin Offset) / 156" * 1800 (Pin Weight using dee004's #) = 1782.7 lbs sit on the rear axle, leaving 17.3 lbs to be carried by the front axle. Is that right?
My Truck Garage:
Tow Toy Garage :
post #6 of 24 Old 04-20-2012, 12:27 PM Thread Starter
Glow Plugs Only
dee004's Avatar
So from the formula above weight transfer to the front axle would be quite negligible almost nil.
I went to the following site and punched in the numbers requested into the boxes of their weight clculator for fifthwheel trailers. It works on a 25% safety factor so all of us with F250's GCVWR of around 23,000LBS towing fifthwheels shouldn't be towing anything over 7000 LBS. Check it out it's quite interesting. Not quite sure how accurate though.
Fifth Wheel Weight Calculator
dee004 is offline
post #7 of 24 Old 04-20-2012, 12:41 PM
WD40's Avatar
Quoted: 31 Post(s)
I always weigh twice if I want to know the pin weigh. Put truck and RV on the scales, while I am there I pick out something on the ground near the left front tire. I then drop
the RV and go back and reweigh just the truck making sure I get as close to where I was when I went though the first time. Subtract the first Rear Wheel weigh from the first one.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #8 of 24 Old 04-20-2012, 12:51 PM Thread Starter
Glow Plugs Only
dee004's Avatar
Doug
I can't do that because I'm trying to figure out what I can and can't tow because I'm in the process of shopping for a replacement 5er. And as you know the RV dealers are absolutely no help what so ever. All of a sudden they become totally evasive. Want your business but offer no help at all. I know each and every truck differs due to accessories loading etc, but there has to be an average ball park figure out there to work from.
dee004 is offline
post #9 of 24 Old 04-20-2012, 12:52 PM
Quoted: 304 Post(s)
Garage
I've seen that calculator before. Like you, not sure on it's accuracy. Could be I don't fully understand it. If they are right, why do we buy these behemoths thinking they can pull a lot if they really can't?
Look at Ford's Towing Guide - I input 2005 for your truck dee004. Look under the Fifth wheel towing, 6.0L, SuperCab column. It's more than 7000lbs.
https://www.fleet.ford.com/showroom/...05_default.asp
My Truck Garage:
Tow Toy Garage :
post #10 of 24 Old 04-20-2012, 12:59 PM Thread Starter
Glow Plugs Only
dee004's Avatar
Good site There looks to be quite a bit of information there. I will go through it and see what I can come up with. Gotta go out to a meeting and will get right on it when I get back in, Cheers.
dee004 is offline
