| Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect... |
Can I haul a 15,000lb boat?
I am considering hauling a 43', 15,000lb boat on a triple axle bumper pull trailer. I haven't hauled this much weight before and wanted to get some opinions. My truck is a 96 F350 CC, 4x4, Long box non dually ( 7.3 of course ). Its got 257,000 miles on it with the original transmission. Most of the truck is stock and original. What do you all think? Oh yea, I will also have about 2000 lbs of veg oil in the truck bed. The haul is 2100 miles, from Michigan to Arizona.
It could most likely do it (the pull) But would it stop in an emergency? Also, you are crossing state lines, other states have different attitudes about over weight pulling............
will the truck pull it? YES
will the truck stop it? NOT QUICK ENOUGH will you more than likely get a ticket? NO, if you have current tags on the boat most troopers are not gunna pull you over for a large boat, unless you have to go through a weigh station |
Wouldn't the trailer brakes aid in the stopping? I tow boats and RVs a couple of times a month for hire. I have MC and Dot numbers so am technically supposed to go through all the open weight stations. Why would a weight station be a problem?
Right off the bat, you're gonna be way over GCWR. (Not just a bit)
With the 7.3L OBS and the auto with that kinda mileage, its going to be pushing things. I'm assuming the 15K doesn't include the weight of the boat. For sake of argument 7.5K truck, 3K in Veg Oil passangers and luggage, 15k boat, and another 3K trailer. 28.5K??? Its a stretch for a stock 7.3L with that kinda mileage and the auto trans. Stopping it will be next to impossible. I would not for the life of me make the trip over the Rockies with that load and that truck. You're in for a nightmare on the mountain passes. You have to be ready for the truck to make that trailer stop if the brakes fail, which that old OBS won't be able to do on a grade. If something happens along the way, you'll be facing serious court litigation. I can't say as to a state requireing you to pull over at any time with that load, but depending on how much you sag its gonna be a flag to some troopers out there. |
whether you have DOT numbers or not your truck and that trailer would not be rated together to carry that kind of weight LEGALLY
That's correct, if the OP gets flagged down for a weight check, he might as well disconnect the trailer when he stops, because he won't be able to get back on the road. And there will be additional fines and charges on top of that, depending on the state it happens in.
Thanks guys, I appreciate the feedback. I will defiantly pass this one up. Typically the most I pull is around 8000lbs. I haven't had any problems at all and when I add a weight distribution hitch 8K feels like nothing, even fully loaded with oil. That being said, 8k is a heck of a lot less weight the 15k.
Thanks again |
until i got below the legal weight then i could go on my way, also 2000 dollar fine
