| Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect... |
2 jeeps and a bumper pull
I'm looking to tow 2 Jeeps weighing about 10k. I have access to a 35 foot bumper pull 2 car open trailer. My question is would I be able to tow this from Ohio to Moab Utah and back with my srw 06 f350 powerstroke? Ive been told by a Guy that tows commercially that I couldn't do it with my srw truck and I could need certain dot certification in some states? Ohio included. Thanks for the help.
How much does the trailer weigh??? that much weight on a bumper pull would be a bit sketchyy.. does it have weight distribution?
Its a regular 2in receiver. It is not actually on the bumper.
Total weight around 13k with trailer |
check the toung weight, if it is the specs for ur truck, then you will be fine. as far as DOT thats a diff animal. if it is reg, in Co then you would need a DOT, but would be fine if it is only just the one trip. but if you plan on doing it more/pulling lots of weight then yes. at least here the # is free to get.
Its a imperial car trailer Tri axle.
What are you guys talking about when you say weight distribution? |
Common Weight Distribution and Sway Control Questions | etrailer.com |
Been there and have done that. |
Should be able to pull it just fine. Just make sure you have a good hitch and ball in your receiver. Weight distribution is a good idea as well.
As to DOT no worries unless you have commercial tags |
