Need Some Help with a "POP-UP" 5th wheel pin - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 11 Old 04-22-2010, 04:53 AM Thread Starter
My truck has a pop-up 5th wheel pin in it. I cannot get it to go down. I have no idea how long it's been up. Does anyone have one of these? Is there a certain trick to getting it down? I have beat on it top and underneath the truck, with no results. I don't want to have to take it off the truck. Any help would be appreciated. Thanks
BigDs_2000 is offline
post #2 of 11 Old 04-22-2010, 05:04 AM
SuperStroked's Avatar
Pop up 5th wheel pin??? Never heard of it... maybe you mean gooseneck ball???
Maybe post a picture of it.
2005 F-250 CC FX4
SCT-Dyno Tuned by DJ/Gearhead/Innovative - Still running strong!!
14.41 in the 1/4 mile
4" MBRP / Volant Intake / Accufab / Autometer Gauges
Trusted Performance Stage 1 w/Crossover
Liberator Performance o-ringed heads
5.5" DR with 5" DR plush rides
1" CJC Traction Blocks
36" Mud Country's
SuperStroked is offline
post #3 of 11 Old 04-22-2010, 05:45 AM Thread Starter
Yes I'm talking about a gooseneck ball. Sorry
post #4 of 11 Old 04-22-2010, 06:19 AM
Hawkerhino's Avatar
is it a side flip or a flipover (take it out and turn upside down)? there should be a leaver under the driverside fender to pull the lock pin out for a flipover. WD40 might help if it has been in for long or pull under a good tree limb and use a hoist to put pressure on it before hitting it to see if it will come loose.
had a receiver that was in for years that i had to hook to a tree and almost break a 30,000 lb towstrap on to get out......
New 2010 F-250 CCLB 4x4 King Ranch, UWA Box, 20 stock KR rims, waiting for more $$$...
****SOLD****00 F-350 CC DRW SWB 4X4 Cold Air Intake, 4" downpipe-5" exhaust, PHP 6 setting chip, GlowShift triple guages, drilled and slotted rotors, 80 gal aux fuel tank
Hawkerhino is offline
post #5 of 11 Old 04-22-2010, 07:19 AM Thread Starter
It slides down in a cylinder. There is a handle in the wheelwell. It says to push it in and the ball will go down. Whats a good rust remover that I could use? WD40 didnt work Liquid Wrench didnt work. 5lb sledge only wore me out.
post #6 of 11 Old 04-22-2010, 07:22 AM
DBM
try PB Blaster
"have not shot the gun yet but will next week when we see the mother in law." Quoted from a gun forum!
2004 CC 6.0 4x4 lariat
MODS: BPD Remote Oil Cooler, MTW Stage 1, GoGo Diesel Direct Drive Soleniod, Swamps 58v FICM, ARP's, Sinister EGR Delete, SCT XCAL3 w/DJ's Looney, Dfuser coolant filter, 4" straight pipe, Ranch Hand, Tuff-Country Level Kit, Isspro Boost/Trans Temp/Fuel Pressure/Pyro gauges, Edge Insight CTS...
DBM is offline
post #7 of 11 Old 04-22-2010, 08:04 AM
cpayne6335's Avatar
My original one we a flip style, and it was stuck down. I tried everything and could not get it to flip up. Even after I got the whole thing out, I soaked it in oil and still could not get it out. I would say heat it up some, but that will stress the metal and make it worthless. You can try to heat it up a little bit, but I personally think it is better off not to be heated, even with a propane torch.
At least your is up and you can use it!!!! It just sux when you need 2 hual something in your bed.
Looking for a FORD.
Chris
US Army, MOS:88M Ft. Lewis 17th Fires
cpayne6335 is offline
post #8 of 11 Old 04-22-2010, 11:51 AM Thread Starter
Thats true, but I don't own a gooseneck trailer, so it is pretty useless to me. I did get some BP blaster, so far it hasnt made a difference either. I havent completely given up tho.
post #9 of 11 Old 04-22-2010, 12:09 PM
i have the kind where you pull it out and flip it over to make the bed falt. I had same problem beat the hell out of it from the bottom and top would come up half way. I tried for like an hour use a whole can of pb blaster.. My older brother come over the next day pulls pin grabs the ball pulls up slams it down and then pull it up out of the bed. ticked me off to no end.. So maybe have someone else try.. LOL
99 f350 stoker crew cab dually 4x4
rebuilt trans(ford rebuild)
straight piped
diy intake
mods wanted
4inch exhaust
6.0 trans cooler
6.0 inter cooler
guages
chip
08 mirrors, tailgate
05 conversion
fordboy84 is offline
post #10 of 11 Old 04-22-2010, 01:13 PM
1tonpower's Avatar
Send a message via AIM to 1tonpower
kroil its the best there is when it comes to penetrating oil
08 f350 KMC wheels with 33" MTZs, bed rails with a reese 20k slider, 5% tint all around, 60gal fuel box, kenwood monitor, afe drop in filter, livewire w/innovative tunes, sinister egr delete, twisted stage 3 trans
1tonpower is offline
