Helper Springs - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 4 Old 01-29-2010, 08:49 AM Thread Starter
ffdono14's Avatar
Helper Springs
What is the best helper spring set out there for my 1999 F250? I dont tow all that often, so i really have no true need for airbags, however when i tow my 7000lb camper, i would like some extra stability, and less sag. I have browsed a little, but not sure where to start. Whats the best for my money?
Thanks
Late 99 F250
Ext. Cab Short bed
DIY Intake
Smoked Corner & Cab Lights
20% tints all around
In the (Near?) Future
Muffler Delete
2-4" lift
33" tires
Guages and TW Chip
ffdono14 is offline
post #2 of 4 Old 01-29-2010, 10:12 AM
1tonpower's Avatar
Send a message via AIM to 1tonpower
get a pair of 350 springs with helpers and youll peaces for the frame that the helpers rest on also. go the hit the junk yards
08 f350 KMC wheels with 33" MTZs, bed rails with a reese 20k slider, 5% tint all around, 60gal fuel box, kenwood monitor, afe drop in filter, livewire w/innovative tunes, sinister egr delete, twisted stage 3 trans
1tonpower is offline
post #3 of 4 Old 01-29-2010, 10:21 AM
tubular031's Avatar
I would do airbags. this way you can control how much help you get. Plus if you ever get somthing bigger you already have them!
I pulled my 5er just fine till I put the tank in the bed. the extra 90 gal made the ride very bouncy and sagged my back end bad. There were airbags on the truck when I got so I pumped them up and what a difference it made. I now have the incab controler and can inflate/deflate them on the fly as needed. very nice to have. Bags are probably cheaper then springs unless you find someone that installed a lift or a junk yard part.
and some 250s already have the same springs as the 350 srw. what is the gvwr on the door sticker?
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #4 of 4 Old 01-29-2010, 10:55 AM
fordfan30's Avatar
Get a weight distribution hitch and leave your truck alone
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
