Adding a 7 way in the bed - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 9 Old 08-29-2009, 06:45 AM Thread Starter
LSU Tigers's Avatar
I would like to add a 7 way plug to the bed of my truck for 5th wheel towing but would like to keep it at the bumper also. Any suggestion I have looked online and i could not find anything.
LSU Tigers is offline
post #2 of 9 Old 08-29-2009, 06:51 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Just build your own wiring harness that splices in to the bumper plug and run it in to your bed to where you are mounting your new plug!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 9 Old 08-29-2009, 07:08 AM
its advised not to splice into factory wiring, nothing but trouble down the road as far as corrosion
best advise is to make a pigtail that plugs into factory plug and run it up to where you want acc plug.
we have had trailer dealers install plug in bed by splicing into factory harness and 1 year later regretted it, but i live in nw ohio, tons of salt in winter
roadrunner is offline
post #4 of 9 Old 08-29-2009, 07:12 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
dont splice into the factory harness, go to the plug on the bumper... cut factory plug off, install new one and have the wires for the bed plug tied into the plug at the bumper. solder the wires.. that way if there is an issue its at the plug near the bumper and its an easy fix. i have done this to several dozen trucks and works like a charm. only bad thing about it is you have to replace the plug at the bumper so you can tie the new one in for the bed
post #5 of 9 Old 08-29-2009, 07:14 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Correct If you use good connectors and heat shrink tubing this is the way to go
If you go that route you will not have corrosion problems. Heat shrink is key. I also recommend Wire loom over the top of this
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 9 Old 08-29-2009, 07:20 AM
Napa sells a harness just for this, you unplug the connection behind your bumper plug and it plugs in between using the factory style connectors. Then it has a 7 wire lead that you run up to the bed for your plug.
Edit- can't find that in the napa catalog anymore, but i know I've seen them online before. I'll keep looking
Found It!
Pollak 5th Wheel / Gooseneck T-Connector with 7-Pole - Ford, GM, Nissan w/ Factory Plug PK11893-11932 : Trailer hitch bike rack and trailer hitches - etrailer.com
It even has a factory style sealed connector for use in the bed! Thats the most bulletproof way to do it. No messing with your factory wires.
2002 F350 SRW Crew Cab Shorty Lariat
Torredor Red - 7.3, Viper 5701
Silverline 4" TB Exhaust
Power Hungry Performance FU Chip
Autometer GS Gauges
md18 is offline
post #7 of 9 Old 08-29-2009, 07:52 AM
Quoted: 6 Post(s)
I should have mentioned wire loom and heat shrink but I didnt think about it!
post #8 of 9 Old 08-29-2009, 08:00 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Found It!
These work good but use dielectric grease between that harness and the factory plug and use electrical tape to seal the area between that plug and the factory one. If you dont you will have a corrosion problem. I have used that particular one on 2 trucks and both came back to haunt me.
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 9 Old 08-29-2009, 09:46 AM Thread Starter
LSU Tigers's Avatar
Thanks i just bought one. And will do on the grease and tape
