Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
Old 02-17-2007, 10:03 PM
Todd Munns Todd Munns is offline
towing two rigs
Ok here is the deal, I have a 2000 F250 diesel 4x4 crew cab. I would like to trailer two IH scouts approximately 4,500 lb ea. to Moab, Utah about 2,000 miles round trip through a couple mountain ranges. I was going to pull a 30' gooseneck trailer. Am I crazy? Do I need a F350 dually or is my truck set up for such a load. I do have trailer brakes and I will add air bags to the back. It is also a shortbed if that matters. Any help in this decision will be appreciated.
Old 02-17-2007, 10:22 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
welcome to the forum bud
9k lbs plus the weight of the trailer i dont think youll have any issues you have a hoss of a truck and i think youll be fine
Old 02-17-2007, 10:36 PM
Hayman Hayman is offline
I think the max you can go is 26k total you should be fine.do you have a trans temp in your truck?
Old 02-17-2007, 11:07 PM
Marty Marty is offline
International Threat
Max GCVW rating for your truck is 20k. Many tow MUCH higher then that though. Take your time, be safe and check everything ahead of time. Enjoy your trip.
Old 02-18-2007, 12:53 AM
straycat straycat is offline
I'm not sure about down there, but up here you insure your rig for the amount of weight overall your truck will be in total, so you might want to check to be sure your covered for it, insurance wise before your trip.
Gord.
Old 02-18-2007, 07:59 PM
towing
I don't have a trans temp guage, but I will install one before the trip. Thanks for all the help guys.
Old 02-20-2007, 12:13 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
I have seen our truck pull alot more then roughly 14,000 pounds, I am guessing 9000 for the two scouts, then another 5,000 for the trailer, your truck curb wieght is around 8,000 pounds. There for your GCVW is roughly 22,000 pounds. Do you have to go through the rockies to get to the Moab. Or are you on the west side of the rockies already. Make sure you got a good set of brakes on your truck and trailer. Take you time go slow, and please make sure you have your wieght on the trailer properly. You may want to think about an exhaust brake as well.
Old 02-20-2007, 12:33 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Allow good stopping distance and you will be just find.....
Old 02-20-2007, 01:29 PM
Yup, with that kind of weight, you don't want to go rushing down the big hills, I've got an exhaust brake, and it's worth it's weight in gold in the mountain's.
Gord.
Old 02-22-2007, 09:33 PM
I do cross a couple mountain ranges, but we just skirt the bulk of the rockies.
