6.0 engine and trans - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-30-2014, 07:53 PM Thread Starter
lariat73's Avatar
I have a 2004 6.0 engine and transmission
Engine $3500
Trans $750
Both are factory with 146k miles and operate perfect
Can be test driven before removal if need be
Will take a complete core engine and $2500 for my engine
01 ccsb srw 350 4wd ffd injectors 4" exh ts 6pos reg return
00' ccsb 4wd 350 4in lift 20x12s leather and suede custom interior BTS built axles aeromotive fuel sys
NO ENGINE
(7.3 full rebuild in progress)
lariat73 is offline
post #2 of 2 Old 11-24-2014, 01:56 PM
Firewood Hack
Locust Cutter's Avatar
Send a message via MSN to Locust Cutter
Did you ever sell them?
Bryan TAPS Member
TSgt KSANG
Computer guy now, but former B-1b and '135 Crew Chief
"IYAMYAS" -"Kicked the tires and lit the fires!!!"
'03 F-250 6.0/5R110 4x4 RC/LB, 4" diamond eye exh, SCT X4, EGR missing, ARP studs, new oil cooler... (joint venture between Dad and I)
'02 F-350 CC/LB Flatbed Dually 4x4, 7.3PSD/ZF-6 -WW2, gutted factory exhaust, F.F. Stage 1's, 6637 filter, TS6 w/tunes by Matt and gauges.
'01 f-350 gasser/hand shaker 2wd - Burned to the ground
Locust Cutter is offline
