6.0 trouble in Hays, KS - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-14-2013, 09:51 AM Thread Starter
Krug's Avatar
Quoted: 17 Post(s)
Hi I just got done doing a stud and injector job on my 04 f-250 with the 6.0 and when I stated it up I heard a whooping noise, after some research it looks like I have some valve train problems from not correctly setting the dowl pin. Now I am just kind of lost as of what to do, I have the drivers side valve cover off now.
Thanks for any assistance
Krug is offline
post #2 of 6 Old 12-18-2013, 09:56 AM
Firewood Hack
Locust Cutter's Avatar
Send a message via MSN to Locust Cutter
I wish I could help you Man, but I didn't have my 6.0 long enough to get the wrench time to know how to help you on that... Chris maybe?
Bryan TAPS Member
TSgt KSANG
Computer guy now, but former B-1b and '135 Crew Chief
"IYAMYAS" -"Kicked the tires and lit the fires!!!"
'03 F-250 6.0/5R110 4x4 RC/LB, 4" diamond eye exh, SCT X4, EGR missing, ARP studs, new oil cooler... (joint venture between Dad and I)
'02 F-350 CC/LB Flatbed Dually 4x4, 7.3PSD/ZF-6 -WW2, gutted factory exhaust, F.F. Stage 1's, 6637 filter, TS6 w/tunes by Matt and gauges.
'01 f-350 gasser/hand shaker 2wd - Burned to the ground
Locust Cutter is offline
The Following User Says Thank You to Locust Cutter For This Useful Post:
Krug (12-19-2013)
post #3 of 6 Old 12-18-2013, 10:01 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I'm gonna say you have a bent push rod causing the issue. Check #5 cylinder since that seems to be the most common one to cause the problem.
dhanna6powerstroke is offline
post #4 of 6 Old 12-19-2013, 03:21 PM Thread Starter
Krug's Avatar
Quoted: 17 Post(s)
Update, found that I had a bent push rod on the drivers side I think it was cylinder 4, went ahead and replaced it and that problem seems to be solved because there is no loud knocking noise now, but it is now running rough and I am getting an unbalance code from cylinder 5 and a low injector from 5, probably just going to take it to the dealer tomorrow because I don't have any more time to work on it.
Would a bad injector cause these codes to be thrown?
Thanks for all the help
Krug is offline
post #5 of 6 Old 12-19-2013, 03:28 PM
Mod Newbie
Quoted: 20 Post(s)
Pull the injector plug and make sure that you didn't bend a pin over when you connected it.
post #6 of 6 Old 12-19-2013, 03:32 PM Thread Starter
Krug's Avatar
Quoted: 17 Post(s)
It looked ok last night, after getting the code I pulled the injector and replaced the copper washer and all seals and reinstalled, did not make much difference if any.
Krug is offline
