where can i get my stroke rebuilt?? ? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-06-2009, 06:09 PM Thread Starter
b.edens's Avatar
Send a message via Yahoo to b.edens
Arrow where can i get my stroke rebuilt?? ?
Hey guys just got an 02 f-350 SRW and I need to know where to get the motor rebuilt, I want it done right 30 over and clean. New injectors, yes NEW probably a bigger turbo etc. someone that has the resources and tools will stand to make a little bit of money off me. the rebuild kit is under 1k from FORD. I will but that part. I just need someone to do the work. also I am going to get new injectors and a better turbo and all the goodies. I want to know who wants to do the rebuild and install. Also I want all that done so I can add an economy chip and stacks Well or a crazy lary program and economy. but what ever. So heres the challenge, who can do ALL of that work? and bid low, the lowest bidder gets it and BTW I do tip and I can deliver anywhere north of San Antonio
1997 F-250 4X4
Crewcab short bed
Ranchhand front and rear replacement
460 cu. in.
Bored .060 over
JE Pistons
Forged Conn. rods
Forged Crank
Thin Headgaskets
Stainless Steel Valves
Heads Ported And Polished
Custom Comp Cams Grind
Previous owner said Dyno was 551.6 on the ground in 2wd'
Gets 8 MPG max
38 gallon rear replacement tank form LMC
AND ..... MORE
b.edens is offline
post #2 of 3 Old 10-06-2009, 06:12 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Check out Cen Tex Diesel performance.
Is there actually anything wrong with your rig? Or are you just wanting to rebuild it.
Oh and stay away from generic tuners like Bully dog. Custom tunes are the way to go
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 3 Old 10-06-2009, 06:31 PM Thread Starter
b.edens's Avatar
very low compression on 2 cylinders. might as well go for broke and get it all done up right from the get go. runs once in a blue moon for a short time. might just need injectors but i want new internals
1997 F-250 4X4
Crewcab short bed
460 cu. in.
Bored .060 over
JE Pistons
Forged Conn. rods
Forged Crank
Thin Headgaskets
Gets 8 MPG max
AND ..... MORE
b.edens is offline
