97 F250 7.3 cranks but wont start - Ford Powerstroke Diesel Forum
Testing Forum Dont know how to post a poll, picture, Etc....Try it out here first!!
post #1 of 12 Old 04-06-2013, 10:09 AM Thread Starter
Question 97 F250 7.3 cranks but wont start
I have a 97 F250 7.3 that cranks but wont start. Please help. Thanks in advance
luv2ride3 is offline
post #2 of 12 Old 04-06-2013, 11:08 AM
Colin7.3's Avatar
Any smoke out the tail pipe? Any mods done to truck?
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 12 Old 04-06-2013, 01:04 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Check fuel bowl...see if its got fuel. Drain it, and try to crack the truck and see if it fills back up while cranking. If not uts the fuel pump...check oil level too
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 12 Old 04-06-2013, 02:14 PM Thread Starter
Question
Thank you all for the help.. Nothing from the tailpipe and no mods.. She's an old farm truck. Fuel bowl is full of fuel and has 8PSI at Schrader valve, oil level is good. Oil dead headed oil pressure from hpop is over 4000PSI. Tested IPR valve and wiring, all okay. Replaced cam sensor, shows good tach signal over 200RPM. Replaced IPC on left cylinder head. Also replaced the injector control module on the left fender well.. All fuses and relays are good .... And STILL wont start. Just cranks and cranks. Even put 2 new batteries in her. UGH.. She will barely even run on starting fluid.. Possible timing chain? Jumped time? Shows 180,000 on the odometer. Thank you all again
post #5 of 12 Old 04-06-2013, 02:44 PM
Doesn't Even Care
Quoted: 69 Post(s)
no, it cant jump time.....no timing belt.
do you get a wts light?
Nick
"The Mistress"
post #6 of 12 Old 04-06-2013, 03:37 PM Thread Starter
Okay, is it possible the timing chain stretched & jumped time? Yes I do get a wait-to-start light..
post #7 of 12 Old 04-06-2013, 05:03 PM Thread Starter
has anyone heard of exh pressure sensor shorting out and creating a no start ? thanks .and I see that it is gear to gear drive on the cam and crank so that rules out timing jumped .
post #8 of 12 Old 04-07-2013, 03:53 AM
Doesn't Even Care
Quoted: 69 Post(s)
never heard of that. And it would only give you a code not a no start.
Nick
"The Mistress"
post #9 of 12 Old 04-07-2013, 03:54 AM
Doesn't Even Care
Quoted: 69 Post(s)
Could mean your idm is gone...good way to test is find a buddy with one and swap it out and see rather than buying one.
Nick
"The Mistress"
post #10 of 12 Old 04-07-2013, 04:09 AM Thread Starter
I took the idm out of this truck and put it in a friends truck, his was a 94 model, same vin f motor, his would not start with it. bam thought I had it , ordered one from parts store, 400 dollars later still no start . ok maybe bad part, got another one, same thing Could there be something shorting out, taking out the idm? Thanks again for the info! I'm down to my last nerve....
