| Tennessee Powerstrokes Tennessee Powerstrokes Chapter Area |
exhaust
i know on gas burners in tennessee you dont have to have an exhaust as long as you have a cat. is it the same for diesels? becuase i took my exhaust off last night and am just runnin a cat and im gonna get it shot out the side before the tire if this is the case. will i run into any back pressure problems?
i don't have a cat or muffler i have straight 4in and no back pressure problems so you should be good to go you should stack it
ya i was thinkin bout one on the right side
Prior to 03 there are no emissions requirements on diesels...
Depending on where you're at around here though, depends on wether or not they know that seems like. Hollow out your cat, and push it out somewhere behind the cab and you should be good. |
i can make ya a deal on a complete setup of dual stacks or make a single
I removed the cat, then just took the heat shield that goes between the cat & the floorboard and welded it upside-down. Now when he looks under the truck with the mirror, he sees the shield & thinks it is the cat. |
Think the county laws are more based on what the truck came with, needs to be seen. Up here in hicktown there's no testing though lol |
Hey Will, I have a 3 1/2" straight pipe with a 6" tip Robbies gave me and I have no problems.
Robbie where is the checking station where they told you we don't need cats? |
tennessee blvd i haven't had a cat for 4 years now
