TCE/Wilwood Front and Rear Big Brake Kits - Ford Powerstroke Diesel Forum
TCE Performance Products TCE Performance Products
post #1 of 15 Old 06-23-2013, 09:54 AM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
Introducing the TCE/Wiwood front and rear BIG BRAKE KITS.
Below are current descriptions of our kits and fitment comments pertaining to all 1999-2012 F250/F350 Vehicles.
The TCE 16" Front Kit:
This monster size kit is what started it all for the truck kits! We take the popular and proven Wilwood TC6R caliper and pair it with their massive 16 x 1.375" wide directional cast, 60 vane rotors for superior thermal management. The larger rotor leverage is key in torque production while it also greatly increases thermal capacity over the stock rotor. In short efficiency is greatly increased and fade is greatly reduced. While we don't make huge claims of stopping distance changes (often tire limited) what we can tell you is that they will stop as every time as the do the first time- and that's really what big truck kits need.
Combined with our in house produced Radial Mount Brackets and customized Wilwood rotor hats we've produced the following finished product!
Each Front kit includes:
16" Rotors
TC6R calipers
Brake pads
Aluminum rotor hats
Mounting brackets
Stainless Steel flex hoses (various lengths)
All required hardware
Installed these awesome kits not only look the part but work as well!
So, what could make such an awesome kit even better? Why adding a REAR kit of course!
Don't overlook the value of a rear big brake kit folks. The rear end of your truck is heavy. And if you tow that means even more weight. Just like your trailer brakes help slow the trailer the rear brakes can help slow the truck. Where there's weight there's a need for brakes. Once again we take the TC6R caliper and fit it to another massive 16" disc. But this time we pair it with our custom iron rotor hat to retain the full factory parking brake. A drop on fit this rear kit replaces the one piece rear rotor with our two piece design and six pot caliper. Custom radial mount brackets, hoses and hardware as required. Combined with the front this shifts about 3% more rear brake bias into your rig offing not only not only greater thermal capacity but nearly 20% more total brake torque over stock.
Each Rear kit includes:
16" Rotors
TC6R calipers
Brake pads
Iron rotor hats/drums
Mounting brackets
Our kits are offered in both BLACK and RED pre applied powder coat colors. Optional YELLOW, SILVER and BLUE can be had by special order. We also offer optional ($135 per kit) cross drilled/slotted rotor finishes.
TCE PRICING: What you've been scrolling down for the past five minutes. Get to the point; how much is it?!
1999-2004 and 2005-2012 FRONT KITS $3195
1999-2004 and 2005-2012 REAR KITS $2889
But from now through the end of JULY you can pick up the following deals on our kits!
Any FRONT Kit: Get $250 off
Any REAR Kit: Get $250 off
Any COMBINED FRONT and REAR Kit: Get $600 off!
Yes, that's a full $600 savings on a combo purchases. Not $6084 total but only $5484! This is the deal you've been looking for on the kits you need. It won't get any better than this.
All the Details:
  • Build time is usually 10-14 days depending upon inventory and the order.
  • All kits require 20" or larger wheels. Please see our Wheel Fit page for more spoke clearance info.
  • Kits include red or black powder coat standard. Optional colors by special order and can take up to six weeks.
  • Standard rotors are slotted only. Optional X drilled finish add $135 per axle.
  • Front kits supplied with BP20 high heat pads and BP10 rear pads.
  • Shipping is NOT included. Expect upwards of $200 for the east coast.
  • Calipers, pads, rotors are drop shipped from Wilwood, TCE product from our shop in AZ.
  • Standard front ss hose kits are 29" long. If you require longer we stock +2.5 and +4.0. Custom lengths available but non exchangeable.
  • Standard rear ss hoses are roughly 8" long and connect to the hardlines. Custom lengths and specs are available but non exchangeable.
  • Rear hats are iron and powder coated black. They are fit for stock rear parking brakes.
  • 1999 front kits fit F250/350 and Excursion.
  • 2005 front kits proven to fit 2008 to 2012. Research shows they should also back date onto 2005-2007 vehicles.
  • All rear kits require trimming of stock dust/backing plate for clearance.
  • All rear kits are currently SRW fit only.
  • Optional DRW kits are available by request, please contact TCE for more info.
*Please note: TCE is not a truck expert. We have done our best to assure buyers of the fit of these kits. The late model 2008+ trucks are full plug-n-play. Earlier vehicles and optional DRW trucks may pose yet unknown issues. Please consult with us prior to your purchase to evaluate your needs fully. We want you happy with your purchase and rely on customer input at times for helping establish some of the quirks often associated with such cross fits.
And we do the FACEBOOK thing too!
Your one stop...for Wilwood brakes.
Todd TCE is offline
post #2 of 15 Old 06-24-2013, 06:55 AM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
What do you get for $5500?
Complete set up of course! No hidden parts or odd items to search out...doing our best to assure you that what you see is both what you get, AND what you need.
Optional longer hose kits for the front are available for you guys with lift kits. Both 2.5" and 4" longer kits serve most needs.
*Shown with optional cross drilled rotors.
Todd TCE is offline
post #3 of 15 Old 06-25-2013, 11:52 AM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
They say bigger is better and here's the proof:
Todd TCE is offline
post #4 of 15 Old 06-27-2013, 04:43 AM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
Drilled rotor option:
[IMG][/IMG]
Todd TCE is offline
post #5 of 15 Old 06-27-2013, 03:29 PM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
UPDATE on fit:
The late 2012 and 2013 trucks will not accept the current kits as hoped. There are difference in the knuckles and caliper mounts that are not the same as the earlier trucks.
We've down dated the current kits to reflect fit up to mid 2012. Currently working with a customer who claims to have a late '12 and we have to work on fit issues. I've not personally checked the build date on it but as soon as I see it or can make for some easy look-see inspections as to what to look for I'll update this again.
Todd TCE is offline
post #6 of 15 Old 07-01-2013, 10:49 AM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
No special work to mount these as our billet aluminum brackets bolt right up and use the stock bolts. In this case; trim the dust plate back is required and then shims are supplied to move the bracket a bit to center the caliper.
Todd TCE is offline
post #7 of 15 Old 07-05-2013, 11:10 AM
MorganM's Avatar
Quoted: 3 Post(s)
Regarding the front kit for a 2012;
Are the pistons sealed?
Will I feel any change in pedal effort/ movement?
Thanks- the kit looks awesome!
MorganM is offline
post #8 of 15 Old 07-05-2013, 01:13 PM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
The TC6R truck calipers are non booted calipers. This is true of roughly 95% of the Wilwood product line. Having used and sold their calipers for roughly 20yrs I've seldom seen this to really be an issue. Including a customer with over 300k miles on a kit. (car)
Yes the feel will be slightly different; firmer, more responsive and more linear.
You're welcome. The work as well as they look.
Todd TCE is offline
post #9 of 15 Old 07-07-2013, 01:05 PM Thread Starter
Todd TCE's Avatar
Quoted: 2 Post(s)
Carry @ CT Performance helped complete the Excursion and earlier F250 kits a couple years back. He'll be available also to offer you these kits now and in the future if you send your truck in for other work at his shop.
Todd TCE is offline
post #10 of 15 Old 07-14-2013, 08:49 PM
chodifer's Avatar
Do you see a solution for the 2013 trucks? Would love a set for mine
chodifer is offline
The Following User Says Thank You to chodifer For This Useful Post:
InMotionJosh (01-21-2014)
