Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
  #31 (permalink)
Old 06-10-2009, 07:15 AM
SAK SAK is offline
Originally Posted by doubledrop View Post
actually no, his shudder is not axle wrap, it is the carrier bearing that needs to be dropped to adjust for the angle created by the lift.
Under acceleration the pinion climbs the ring gear which causes the springs to wrap. Which will make the u-joints out of phase, the carrier drop is only designed to maintain the phasing of the joints. Pinion angle is still critical yes, but by putting traction bars on it will eliminate the wrap which will not allow the u-joints to get out of phase.
  #32 (permalink)
Old 10-30-2009, 12:52 PM
107stroker 107stroker is offline
well put, took me a lot o hours to figure that out
