What is the most recommended ball joint for a Dana 50 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-25-2014, 04:17 PM Thread Starter
Looks like I need ball joints on my 2000 4 wheel drive. What is considered to be the best ball joint to put on it? I tried a search and didn't turn up anyone making any strong suggestions.
I am open
Thanks.
Matthews is offline
post #2 of 4 Old 04-25-2014, 10:38 PM
layson's Avatar
Quoted: 83 Post(s)
If you are running big tires I would run dynatrac ball joints. Best ones you can buy hands down.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 4 Old 04-26-2014, 06:58 AM
Fall Guy's Avatar
Quoted: 7 Post(s)
X2, that's what I'm running on my 01
Fall Guy is offline
post #4 of 4 Old 04-26-2014, 02:14 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Moog joints are an upgrade from OEM
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
