lift question... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-25-2014, 04:35 AM Thread Starter
lift question...
I recently picked up a 02 f250 supercab 8ft bed. The guys at BDS were convinced that any more than 4" of lift would cause issues with front driveshaft length/clearance. Anybody have some experience with this and maybe a better idea of how high I can go?
bjdangelo is offline
post #2 of 8 Old 04-25-2014, 04:37 AM Thread Starter
Never planned on going higher than 8" anyway....driveshafts?
post #3 of 8 Old 04-25-2014, 06:40 AM
Heavy_GD's Avatar
Quoted: 1432 Post(s)
Feedback Score: 3 reviews
So you called BDS, who makes an 8", and they said anything over 4" would cause issues?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #4 of 8 Old 04-25-2014, 06:47 AM Thread Starter
They said that anyrhing more than 4 may require the front shaft to be lengthened or cause clearance issues. I had an excursion that I lifted 6 with no issues.....just wondering if any driveshaft mods are required, or if they're just saying that for the off chance that somebody grenades a u-joint.
post #5 of 8 Old 04-25-2014, 06:58 AM
Heavy_GD's Avatar
you got me on that one.
you will have to run a carrier spacer and yes the longer travel could over extend if you flex it out but "clearance" issues... not clear on that one.
GD
Heavy_GD is offline
post #6 of 8 Old 04-25-2014, 07:42 AM Thread Starter
I think they mean the shaft at the u joint up front due to the sharper pinion angle....not sure though.
post #7 of 8 Old 04-25-2014, 07:47 AM
Heavy_GD's Avatar
Honestly I'm at a loss sure you will wear out front end components but 8" is not extreme.
GD
Heavy_GD is offline
post #8 of 8 Old 04-25-2014, 08:28 AM
layson's Avatar
Quoted: 82 Post(s)
I still have the stock front driveshaft in my truck.... but my transfer case is clocked.
I don't think I have ever seen anyone say you need to lengthen the shaft for a 6" of lift. I think you can get by at 8", but any higher than that you should clock the t-case, than the angles are better as well.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
