Traction Bar Drop Bracket - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-25-2014, 03:10 AM Thread Starter
POWERCHOKER
Dantron's Avatar
I have Pro Comp rear traction bars with a 6 inch lift right now. If I were to upsize to an 8 inch lift, would I be able to use the same traction bars by using a drop bracket?
ID:	278377   Click image for larger version
Dantron is offline
post #2 of 2 Old 04-26-2014, 10:00 AM
jetjock15's Avatar
Quoted: 113 Post(s)
May have to slide you upper bracket backward a bit is all.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
