2006 PITMAN ARM ALWAYS LOOSE!!!! HELP!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-23-2014, 02:49 PM Thread Starter
Dickey's Avatar
Garage
I have 2006 F350 single wheel, I got it with a level kit. I upgraded to a 8" Pro comp stage 1 kit. an since I have had it install my pitman arm bolt always comes loose I have used green, blue, red Loctite an still comes loose within 1500-2000 miles.
I noticed my dads 03 and my brothers 01 powerstrokes have a lock washer on there steering arm an I don't.
anyone have this problem?
2014 Harley Davidson Big Blue Pearl Street Glide
Alpine fairing speakers
12" Ape Hangers
2006 Ford F350 King Ranch
BilletProof Oil Cooler Kit
APR Studs
Coolant Relocate Kit
Blue Spring Kit
New Motorcraft Injectors
8" lift kit 38x13.50x18
STC Edge CTS monitor
w/ Vivian tunes looney tune
5" Exhaust 8" Tip
APE Cold intake
50" Ridge Light Bar
Harley Davidson Black Headlights
Dickey is offline
post #2 of 5 Old 04-23-2014, 03:04 PM
Motomez's Avatar
Mine has a lock nut and Blue loctite Time to go see the dealer as i think it would be hard to find a lock washer that large at one of the Box stores
2002 PHP Hydra Chip, Banks Monster Exhaust John Wood Transmission 6.0 Cooler 06 front Axel Pure Performance 6 inch lift and 4 link 08 Rear springs Fox Racing 2.0 Piggy Back Shocks Raceline Renegade 8 wheels with 35 Toyo RT's Auto Meter Gages PSC Hydro Steering Dorman Bellowed up pipes Ford AIS 08 Tow Mirrors
Motomez is offline
post #3 of 5 Old 04-24-2014, 09:07 AM
jetjock15's Avatar
Quoted: 113 Post(s)
How tight you getting it? Sounds like you have never tightened it enough to fully seat the arm so your not getting the right clamping force from the nut. You need to order the correct socket (46mm I think) and get a 3-4' breaker bar on there and get'r tight!
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 5 Old 04-24-2014, 09:15 AM
Skyd Ram's Avatar
Quoted: 149 Post(s)
There's a good chance that the splines in either the pitman arm or the steering box sector shaft are damaged now. Most like the pitman arm has damaged splines. That allows it to wiggle a little on the shaft that quickly allows the nut to get loose. I would try an new pitman arm and torque it down to spec and then again after a few hundreds miles.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #5 of 5 Old 04-28-2014, 06:42 PM
That nut needs to torqued to 400 ft lbs or more if i remember correctly. I had to take mine to a shop. Hard to get that tight with all the crap in the way. I also put a tack with my mig welder on it so it wouldn't come loose.
Gb
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
