bent frame help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-22-2014, 09:27 AM Thread Starter
bent frame help
hi, im new to the forum and do not really know where to post this but i have a 2006 f250 6.0 cc. the frame i believe is bent 2'' out of whack on the front driver side making it sag 2''. is there any fix to level out the front end without hooking it up to a frame machine. i would like to put 35s on it with out it rubbing 2'' coil spacer? any suggestions
dstince26 is offline
post #2 of 2 Old 04-23-2014, 05:54 AM
Quoted: 50 Post(s)
Don't panic just yet. It's much more likely that you have the infamous "Super Duty Lean". These trucks use OEM springs constructed in Mexico, and that combined with the fact that the left hand side of these trucks is heavier, causes the springs on the left to sag differentially. The left side of the truck has the steering box and column, brake master cylinder and hydro boost, the driver, the fuel tank, and all of the wires and hoses going to the rear of the truck. This causes them to lean to the left. Luckily, coil springs are pretty cheap for these trucks. So instead of putting a leveling spacer on your coils, just order leveling coils and you will solve both issues at once. Just be sure to get a good quality spring that's made with American steel. Checkout Icon Vehicle Dynamics.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
Tags
frame , leveled , tweak
