03 srw f 350 leveling question. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-16-2014, 05:33 PM Thread Starter
200x3wheel's Avatar
Okay I know there is numerous threads and post about leveling the front of a sd truck, but I'm looking for some help or suggestions with my particular situation, so I'm sorry in advance if someone has to repeat therselves.
I have a 03 fx4 srw f350 so from factory sits considerably higher in the rear. I brought it to a local spring shop and they added another leaf in the front which brought it up a bit but still shy about 2 inches. I put on some 315 70 17 bfg ats which rub on drivers side inner fender but passenger side is fine., why is this?
My next question is what is my best bet to achieve the needed 2 inches to bring the front up. I bought a tuff country add a leaf and was going to put that in but was concerned because the spring is the same length as the one the spring shop added.
What are your thoughts also should I be looking into Pitman arm drop, longer track bar or will I be okay.
Thx in advance for the help.
200x3wheel is offline
post #2 of 4 Old 04-16-2014, 06:04 PM
SS4Matt's Avatar
Your truck rubs because the front being lifted from the add a leaf and a stock track bar is making the front axle pull on the drivers side bar mount. An adjustable track bar would be necessary to center the axle. With just a leveling kit a drop pitman arm wouldn't be needed (and I don't think they make them for anything less than a 4" lift if I'm not mistaking)
I would suggest getting a drop shackle/hanger kit to achieve the additional 2" of lift you're looking for along with some new front shocks that are intended for that lift height (your current shocks might be long enough but you never know or if they do stretch they might have a shorter life)
PMF makes a great set of drop shackles and hangers for these trucks. Zone off-road has the least expensive adjustable track bar to my knowledge for these trucks as well
Hope that helps you out some!
SS4Matt is offline
post #3 of 4 Old 04-16-2014, 06:34 PM Thread Starter
200x3wheel's Avatar
Ya was just doing some more reading and realized that the tracking bar is causing the drivers side wheel to be in more then the passenger so ill have to look into that adjustable track bar. I was thinking of just removing the front leafs all together and replacing with a 4 inch spring. Unless it's cheaper just to go with shackles, I'm looking for the most cost effective method at this time, I only have 300 into the add a leaf and already bought taller shocks since I needed new shocks anyway.
But yes thanks for your help.
post #4 of 4 Old 04-16-2014, 08:13 PM
SJB
SJB's Avatar
This is one of the most affordable kits I have found which includes track bar adjustment hardware. They sell the kit alone and with shocks.
EPC: 2" 99-04 Ford F250/F350 Super Duty Hanger Leveling Kit
2" Shackle Leveling Kit
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- DIY Intake w/ AMSOIL 4095 washable/reusable filter
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
