Right side one inch higher then left - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-16-2014, 01:38 PM Thread Starter
dieselburner21's Avatar
Quoted: 8 Post(s)
I installed my 2" spacers last week and install went pretty smoothly. Now that everything is back together and on the ground my passenger front is 1" higher than the driver side. Rear is sitting at 41 inches on both sides and front driver side is also at 41 inches. Passenger side is at 42 inches
When I put the coils back in I made sure that the end was butted up against the stops on the piece that connects to the axle. I forgot to mark the coils when I pulled them, so did I put the passenger side in wrong? The only reason I don't think I did is because the end of the coil is against the stop just like on the drivers side.
Will
2010 FORD F250 LARIAT CCSB 6.4
-H&S Mini Maxx / Edge Insight CTS / 4" Flo Pro Dump / 20" Fuel Hostages / 33" Toyo AT's / Airdog II 4G
2006 FORD F250 LARIAT CCSB 6.0 - TRADED
2000 FORD F250 LARIAT CCSB 7.3 - SOLD
dieselburner21 is offline
post #2 of 7 Old 04-16-2014, 02:41 PM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
Check these threads out its very common
Issues with ReadyLift kit on 2013 F250 - leans 1" to the left & pulls right driving
http://www.powerstroke.org/forum/6-7...aning-bad.html
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
post #3 of 7 Old 04-17-2014, 01:06 PM Thread Starter
Quoted: 8 Post(s)
Thanks for the link, I had read about that but seems like most people was only about a half inch.
Will
post #4 of 7 Old 04-17-2014, 03:09 PM
Quoted: 7 Post(s)
Garage
No problem I would look at pure performace coils or icon coils they will ride alot better than those fabtechs!
9 INCH LIFT
SCT LIVEWIRE SRLxx
CUSTOM STEREO
XDP COOLANT FILTER
RCD EGR DELETE
post #5 of 7 Old 04-18-2014, 06:59 AM
Skyd Ram's Avatar
Quoted: 140 Post(s)
Every truck is different. Like you may have read in those other links provided I've measured trucks at much as 1" low on the drivers side right on the dealer lot. The difference between an empty fuel tank and full fuel tank can make a 3/8" difference by itself.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #6 of 7 Old 04-18-2014, 07:07 AM
ZMANN's Avatar
Quoted: 1596 Post(s)
you don't really mark the coils but you need to make sure the spring end is sitting at the mounts "stop" both the top and bottom implement this "stop"
typically you rotate the loose spring until it hits the lower stop the top you rotate the isolator/spacer until it hits the stop then lower the truck to capture the settings
never worry about the measurements on a truck that was just jacked up drive it a bit
so the suspension can settle
if all above was done properly and your still not level u can check a few other items
but like mentioned if it's not body mounts or a bound suspension it is a characteristic of these trucks and can be dialed in to level with shims under the coils and leafs if desired
We Miss you Ronnie
ZMANN is offline
post #7 of 7 Old 04-23-2014, 03:44 PM Thread Starter
Quoted: 8 Post(s)
Thanks for the replies guys, I don't know how much effect it will have when I install my adjustable track bar but axle is off about an inch towards the driver side. Trying not to let it bother me d@mn OCD
Will
