2000 F250 8" lift question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-14-2014, 08:21 PM Thread Starter
I just had an 8" BDS lift put on my 00 Crewcab shortbed. Everything is great but when I 1st drive off I get a vibration until I get up to 10-15 mph. I have a 2 piece driveshaft and the lift kit came with a carrier bearing spacer that has been installed. I've done some searches and some posts say go straight to getting a 1 piece drive shaft and others say to add pinion shims. I was wondering whats the best beginning strategy?
Thanks
[IMG][/IMG]
Ward1 is offline
post #2 of 13 Old 04-14-2014, 09:06 PM Thread Starter
Ward1 is offline
post #3 of 13 Old 04-14-2014, 09:07 PM Thread Starter
Ward1 is offline
post #4 of 13 Old 04-14-2014, 09:12 PM Thread Starter
Ward1 is offline
post #5 of 13 Old 04-15-2014, 09:44 AM
layson's Avatar
Quoted: 82 Post(s)
Rear pinion angle doesn't look good. That is where your vibration is coming from. Should be pretty close to a straight shot from the axle to the driveline.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 13 Old 04-15-2014, 10:00 AM
hansel's Avatar
Quoted: 95 Post(s)
X2
I would some how try and reduce the angle, can you twist the axle housing so it is putting the drive shaft more in-line???
At that angle I would imagine you will start breaking "U" joint's
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is online now
post #7 of 13 Old 04-15-2014, 01:37 PM Thread Starter
Thanks to you both looks like pinion angle is going to be my project this weekend
Ward1 is offline
post #8 of 13 Old 04-15-2014, 01:42 PM
layson's Avatar
Quoted: 82 Post(s)
Then if you want to get your driveline angle dialed in pick up one of these... you don't need a one piece built.
Quote of the Day:
layson is offline
post #9 of 13 Old 04-15-2014, 07:32 PM Thread Starter
Is there a tech thread on how to add shims? I'd like to try it myself.
Ward1 is offline
post #10 of 13 Old 04-15-2014, 08:28 PM
SJB
SJB's Avatar
Pinion angle is off like mentioned above, and that single carrier bearing shim doesn't seem near enough for an 8" lift.
If a shop did the lift, I'm surprised they would let the truck drive off with everything being that far out of alignment.
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- DIY Intake w/ AMSOIL 4095 washable/reusable filter
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
