Dual Steering Stabilizer (Opposing vs. Parallel) - Ford Powerstroke Diesel Forum
post #1 of 23 Old 04-05-2014, 04:25 PM Thread Starter
SJB
SJB's Avatar
I was looking to possibly get a dual steering stabilizer for my truck, but I had a question between two styles. I found a Fabtech one that utilizes the factory mount linked here.. http://www.fabtechmotorsports.com/files/FT8000i.pdf
It installs where the shocks are parallel with each other. Other kits I've seen run the length of the front of the vehicle and oppose each other.
Is one style more effective than the other, or makes no difference at all?
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- DIY Intake w/ AMSOIL 4095 washable/reusable filter
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
post #2 of 23 Old 04-05-2014, 05:14 PM
E99F350Stroker's Avatar
I'm interested in this too, free bump!
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #3 of 23 Old 04-05-2014, 06:24 PM
jetjock15's Avatar
Quoted: 113 Post(s)
The opposing ones are for nitrogen pressurized shocks like bilsteins, fox or king. Parallel would work for rancho ect. Shocks like bilsteins use gas to keep pressure on oil to reduce foaming, but that gas pressure will exert pressure to extend the shock, which could bias the steering,thus the opposing mounts.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 23 Old 04-05-2014, 06:42 PM
ZMANN's Avatar
Quoted: 1579 Post(s)
to clarify the opposing ones aren't for charged shocks only u see lots of regular hydraulic shocks in that mounting configuration and surprisingly Bilstein sells a singe gas charged for the OEM location i don't quite get that ?
you could even used gas charged in the fabtech mount if you wanted if they would fit opposed
at the end of the day I would go with the topgun customz 2x Bilsteins or better like King
We Miss you Ronnie
ZMANN is online now
post #5 of 23 Old 04-05-2014, 07:39 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I have opposing tied to tie rod and also added another in the stock position after seeing Zman's pictures of his. It honestly made a big difference running all 3. I modified my old Rancho to fit up top after I fabricated a 4" drop bracket for the frame connection.
It has a really heavy steering wheel feel to it know and I get almost no rebound. Very solid feeling at the wheel. Not so sure what my power steering pump thinks about it though, lol.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #6 of 23 Old 04-05-2014, 09:27 PM
Considering that I have run 14.50s without one, I have to ask why you need dual stabilizers on a 2002? I had one for about a month, bent it wheeling one night, and never put another one on.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 23 Old 04-06-2014, 07:28 AM Thread Starter
SJB
SJB's Avatar
I'm getting ready to install either a leveling kit or lift along with larger tires, new wheels, and all new shocks. So I figured I would replace the steering stabilizer on it at the same time. Figure it is probably worn too. Don't really need a dual stabilizer setup, but I've seen some setups that are pretty affordable like the Rough Country one from TGC for $89, and the Fabtech one listed above for $120. So I was debating between the two styles (opposing vs parallel). I liked that the Fabtech utilized the factory mount, but I don't know much about either setup. And to be honest, I haven't really climbed under my truck lately to study the steering setup to understand how it all works together.
And as far as systems to go with, I was really looking for a setup that is less than $150. The more expensive setups would be nice, but just not in my budget at this time. After leveling kit/lift, new wheels, new tires, etc., I just can't afford one of the more pricey systems at this time.
SJB is offline
post #8 of 23 Old 04-06-2014, 07:44 AM
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
If your not running a 6" lift with 37" or larger tires the oem mount will do fine. It's when the truck has to control big heavy tires that that stabilizer becomes very important. Once the tires overwhelm the steering system trust me you will know it.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #9 of 23 Old 04-06-2014, 09:07 AM
Considering that you're debating a leveling kit or a lift, I doubt you're going larger than a 35. Therefore, I would get the lift and tires and go from there. You will know if you have a front end issue.
However, DO NOT install a stabilizer without FIRST making sure all other components are good. This includes adjusting the steering box. A stabilizer can be a mask for other problems.
Karls03 is offline
post #10 of 23 Old 04-06-2014, 09:28 AM
ZMANN's Avatar
mhatlen
Shh
I never tell people I run 3 they whine about 2 sometimes LOL
when I bought my truck it had 35's and death wobble the single Rancho in the OEM spot really helped but duals eliminated it all together.
folks will cry that is a Band-Aid‎ fix but the Band-Aid‎ worked for 20 thousand miles or
more I know have a 4 link with uber adjustable camber so with that dialed in I have not tried running without them and probably won't since even a properly set up steering won't keep the wheel from ripping out of your hands in some situations
the only way I would take them off is to make room for a Hydro assist
We Miss you Ronnie
ZMANN is online now
