Do I need traction bars? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By schlutzer
post #1 of 10 Old 04-02-2014, 07:56 AM Thread Starter
eforkist's Avatar
I've got an 08 f350 shorted dually with 22.5 custom wheels and 36" semi tires. Every time I start from a full stop my rear end feels like its bouncing a bit. Even during slower acceleration it does this. Do I need a set of traction bars or do yawll think it's something else?
2008 f350 lariat/fx4 short bed dually
8 " lift, 22.5" custom 1 off wheels, semi tires
eforkist is offline
post #2 of 10 Old 04-02-2014, 08:44 AM
layson's Avatar
Quoted: 83 Post(s)
I would say yes... check out the F450 in the first video...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 10 Old 04-02-2014, 04:55 PM
POWERCHOKER
Dantron's Avatar
I have a 6 inch lift with 37's on H&S performance tune and just had some traction bars installed. I definitely feel the difference!
Dantron is offline
post #4 of 10 Old 04-02-2014, 10:29 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Do you need them? No.
Will you benefit from them? hell yeah
Heavy_GD likes this.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 10 Old 04-03-2014, 10:30 AM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
Your shifts will feel alot better!
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
post #6 of 10 Old 04-04-2014, 02:46 AM
jetjock15's Avatar
Quoted: 113 Post(s)
It's probably your carrier bearing if your feeling under even light accelerations. I always include a one-piece driveline as mandatory equipment when I do 8" lifts.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #7 of 10 Old 04-04-2014, 07:56 AM Thread Starter
eforkist's Avatar
it probably doesn't help that i have 3 blocks on each side on the rear springs huh?
eforkist is offline
post #8 of 10 Old 04-04-2014, 09:01 AM
POWERCHOKER
Dantron's Avatar
Damn! I didn't know you had 8 inches of lift! They recommend rear traction bars for trucks with more than 3 inches of lift in the rear. If I were you, I would definitely get some rear traction bars.
Dantron is offline
post #9 of 10 Old 04-09-2014, 08:14 AM
Skyd Ram's Avatar
Quoted: 149 Post(s)
Definitely not!
Do you have a 2 piece rear driveshaft?
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #10 of 10 Old 04-09-2014, 08:17 AM Thread Starter
eforkist's Avatar
Originally Posted by Skyd Ram View Post
Definitely not!
Yea. How would a 1 piece help?
eforkist is offline
