95 7.3l f250 rough suspension - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-30-2014, 12:00 PM Thread Starter
Hey everyone I have a 95 7.3l PSD that's pretty much bone stock. When I drive on any kind of bump I slam my head on the roof. The ride is terrible but it's also 19 years old. I was wanting yalls opinion on replacing the front suspension that isn't going to put me in the doghouse or broke. 1995 7.3l PSD extended cab long bed 4wd. Thanks
Medic is offline
post #2 of 4 Old 03-31-2014, 09:15 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
I can't say I have that model of the F250 but I can say go with a quality set of leaf springs and shocks. Icon is as good as they come if you can get them for that year.
Also keep away from large heavy duty shocks, a smaller cylinder shock is going to be much faster in its stroke and slow for spring movement. ( you could pull all if your shocks off and take the truck for a drive xnd see if the stiffness goes away) of coarse you are going to have some major rebound going on but you can determine if your shocks are overwhelming your suspension. I myself am a Huge fan of adjustable shocks and the only ones I will ever use. I have Rancho RS9000 on truck now and really like them.
One other thing to look into is how do your rubber body mounts look?? If the cab has settled and sits lower than the bed on the body lines they're toast.
Last thing is going to be tire pressure, if you are running the max pressure you need to lower it. My tires for example are rated at 3,950 lbs load at 50 psi. I am at: 35 psi frt and 30 psi rr. Tire check with chalk is dead on rolling flat across entire tire. Of coarse this is a unloaded pressure and I bring it up when I pull the trailer or hauling weight.
Good Luck hope this helps you get started.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 4 Old 04-02-2014, 11:28 AM Thread Starter
My bed does ride a ways higher than the front end. I was looking at a rough County set. http://www.amazon.com/gp/aw/d/B00BU9R9HW/ref=redir_mdp_mobile
Medic is offline
post #4 of 4 Old 04-03-2014, 11:15 AM
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
Replace the cab mounts to level that up. The rest is subjective
7" Icon/Carli Lift
Atlas40
4" SS exhaust
58K Miles on it
mhatlen is offline
