Castor adjustments - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 33 Old 03-29-2014, 06:59 AM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Castor adjustments
Well. i just got back from the alignment shop. Truck drives much better with some castor.....Problem was after i installed the 7" Icon i was in the negative and after using the alignment shims or spacers, whatever you call them i only have 1degree positive.(Dont yell at me if i got these numbers backwards, new at the whole castor camber deal!) From reading here these trucks drive better with 4.5-5* castor? Well i have 1* which is way better then the -2 or so i had before.
SO i guess down the road i guess 4-link will allow me to do this.
Another question though.......This may be retarded, but looks like if you flipped the radius arms upside down you could gain a bit. Probably not even possible, but just curious. :hehe
Big_Smokey is offline
post #2 of 33 Old 03-29-2014, 07:49 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Normal, 4link arms or adj replacement arms best option. We carry them .
CT Performance, Inc. is offline
post #3 of 33 Old 03-29-2014, 10:12 AM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
What about the 3- link. What's the deal with them?
post #4 of 33 Old 03-29-2014, 11:00 AM
Quoted: 3 Post(s)
Those are the replacement arms we have and you can adjust the Castor.
post #5 of 33 Old 03-29-2014, 08:56 PM
layson's Avatar
Quoted: 80 Post(s)
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 33 Old 03-30-2014, 06:55 AM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Layson I've read some pretty good debates on the 4-link and 3- link topic. Mostly u and pure performance guy...nice reads
If all immwanting is more castor it seems the 3-link would be where I'm headed. I also like the look of it. Just wondering though it says up to 6" lift.....I'm at 7"....... Will I still have to use my radius arm drop brackets with those?
The Following User Says Thank You to Big_Smokey For This Useful Post:
layson (03-31-2014)
post #7 of 33 Old 03-30-2014, 07:00 AM
Quoted: 3 Post(s)
IMO You still need the drop brackets.
post #8 of 33 Old 03-30-2014, 07:12 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
what about the BD diesel kit. BD Power - Product: Cam Caster Adjuster Kit
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #9 of 33 Old 03-30-2014, 02:57 PM
layson's Avatar
Quoted: 80 Post(s)
If you run a drop Pitman arm and a dropped track rod bracket you should run the drop frame brackets.
Quote of the Day:
layson is offline
post #10 of 33 Old 03-30-2014, 04:41 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Those should be more then capable to adjust out the caster. Last thing you want is to put on drop down brackets, it creates more leverage for deflection of the road forces introduced into the frame. A tall lift will require them and I would only use a top quality set to make sure there is no flexing or deflection.
Those are beautiful radius arms that much is for sure. Does anyone know what a set of them go for?
Stay away from those drop brackets if at all possible they do loosen up the handling I know this first hand.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
