Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 11-27-2008, 04:20 AM
Rattler-FX4 Rattler-FX4 is offline
Stabilizer Kit - HELP
Since my '06 Larait has the Rancho shocks, I was thinking of going with the Rancho stabilizer kit. The dual kit shows being a 2 shock parallel system and I don't want that. So, I was thinking about 2 single kits that way they could run in-line. But, I can't locate the single "kit" part number. Anyone know it?
Also, anyone using the Rancho stabilizers?? What other brands, other than ICON, are being used? Just had our second son so budget is slim right now.
Old 11-27-2008, 04:23 AM
symbols symbols is offline
Nonsense specialist
PM trucktoys. They can tell you if they have the part and show you a pic of it installed
Old 11-27-2008, 06:41 AM
TxFireman1972 TxFireman1972 is online now
I've seen this one on a few truck. Kinda looks like the Rize but alot cheaper. Pretty good price too.
Ford Dual Steering Stabilizer 05-07 F250/F350 Super Duty - Top Gun Customz
Old 11-28-2008, 05:28 AM
DCSpecial DCSpecial is offline
Supporting Vendor
I run an Icon setup on my 07:
Love the setup.
I've ran both nitrogen charged shocks (Icon, Bilstein, etc..) and plain generic white bodied hydraulic shocks and IMO the nitrogen charged shocks perform much better.
We offer a few kits:
BDS Dual Steering Stabilizer Kit - 2005-2008 F250/350 4wd - Steering Stabilizers - Truck Toyz Store
Rize Industries Dual Steering Stabilizer Bracket Kit - 2005-2008 FSD 4wd - Steering Stabilizers - Truck Toyz Store
Icon Vehicle Dynamics 2005-2008 FSD Dual Steering Stabilizer Bracket Kit - Steering Stabilizers - Truck Toyz Store
Icon is the most money, but it's the cleanest looking when installed with the billet clamps that they use on the tie rod.
Old 11-28-2008, 06:47 AM
RRGSD RRGSD is offline
Bilstein shocks
I recently installed Bilstein shocks and a stabilizer on my 2003 4WD 7.3 (No Lift). The shocks were installed with the body up. The original rancho's were body down. Should I re-install the shocks so they are body down? Hwat is the difference?
Also the stabilizer replacement is a generic white shock. The stabilizer was installed at the same location where the brackets were for the original stabilizer. Are we supposed to move the bracket further out when installing a new stablizer. Do I need to make changes or adjustments. PLEASE HELP.
Old 11-28-2008, 10:30 AM
Supporting Vendor
Bilsteins are nitrogen charged mono tube shocks so their orientation does not effect their operation.
You install them so that the decals on them are facing the right side up....which on 99-04s is body up, boot down.
As for any adjustments for the stabilizer, only if the shock you are using has different dimensions/travel you might need to shift the bracket that's on the tie rod to set it up properly.
Old 12-03-2008, 05:46 PM
Thanks all. Decided to go with the Rough Country dual in-line set direct from Rough Country as it was $116 on sale with shock boots. Should have in a day or so and will post pic's when I have them.
Old 12-03-2008, 05:50 PM
TANK'S 250 TANK'S 250 is offline
I hope you'll end up happy with them...
Old 12-03-2008, 05:55 PM
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
Thats a good choice. Ran them on the chevy and they kept my 44's in check!
CAT797 CAT797 is offline
Sparkplugs Not Required
Why do you say that? Have you heard or do you know otherwise? Please share.......I just got my Rough Country kit today from Santa in the Brown truck.
