05 F-350 front hub removal....... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-23-2014, 09:28 AM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
OK so I am taking on the task of replacing the front hubs on the 2005 6.0. Now I have searched far and wide and can only really find videos and write ups on 99 to 04. I have a few friends who have PSD and one has replaced his hubs. He told me I needed the axle nut socket to remove the hubs ect... So I find this socket for $50! But I do some more reaserch and finally find this video with my year. This guy did not use this socket, nor was there any nut like that. All there is behind the locking hub was the snap ring.. I have manual hubs. Is there anyone out there that has the 05+ and has changed the hubs? If so, what specialty tools did you actually need? Besides the snap ring pliers.
2005 F350 XL 6.0
ARP studs
EGR delete
5" turbo back straight pipe
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
All upgraded OEM parts
BigRedOne is offline
post #2 of 6 Old 03-23-2014, 09:30 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Are you just changing the lockout hubs? Or the hub bearing assembly?
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 6 Old 03-23-2014, 10:48 AM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
The bearing assy itself..
2005 F350 XL 6.0
ARP studs
EGR delete
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
post #4 of 6 Old 03-23-2014, 10:51 AM
ZMANN's Avatar
Quoted: 1346 Post(s)
this looks good and it has a link to another write up use both
F-350 Maintenance
We Miss you Ronnie
ZMANN is online now
post #5 of 6 Old 03-23-2014, 10:53 AM
ZMANN's Avatar
u do not need a socket u do need some long reach snap ring/circlip pliers
other than that it's cake since you can leave the knuckle seal unless it leaks EDIT you have manual hubs so you might not care if that seal leaks vacuum other than it may let moisture in
We Miss you Ronnie
ZMANN is online now
post #6 of 6 Old 03-23-2014, 10:58 AM
ZMANN's Avatar
ps the hubs are the external 4x4-4x2 selector and even though people commonly call the bearings a " hub"
the term "Unit Bearing " is better suited specially for searches
We Miss you Ronnie
ZMANN is online now
