cracked procrap bracket replaced by icon - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-20-2014, 08:26 PM Thread Starter
Feedback Score: -1 reviews
as straight forward and simple it is,this is just stupid.
last year my sector shaft snapped,which is a pucker factor of about 12.
well that wild ride along with loose suspension parts led to a cracked track bar drop bracket. so after a little research and opinions the icon unit seemed to be the best bet for my suspension goals.
so simply bust out the 4' long snap on torque wrench and a few sockets. simple R&R right,,,,,wrong
first hurdle-the icon unit is for 4" and 6" lifts. my bracket that came with the lift kit puts the bar hole smack inbetween the two on the icon. so I choose the lowest and move on. then comes the single bolt that attaches the bracket to the engine cross memember. well the 1/2" bolt used on the old bracket is about 1" to long AND to small. the icon seems to require a 9/16" bolt but ill have to drill out the cross memember hole.
so,if anyone is running this bracket,please replie and let me know the route you took.
ID:	260505   Click image for larger version
ID:	260513   Click image for larger version
2000 7.3 ccsb BTS 4r100,frx,coolant filter,custom intake,mbrp turbo back,Php FU,walbro 392,hi flow outlet,turbo master
Pro comp 6.5,bilstein 5160 front/rear,pro comp ladder bars,moto metals/37" hankooks.
n54power is offline
