2000 4x4 front hubs toast - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-20-2014, 06:13 PM Thread Starter
Hey I just got a 2000 F250 4x4, 7.3 . The front hubs are trashed. What is a good replacement for the ford parts. These have lock and auto.
Thanks
Mustang Al is offline
post #2 of 7 Old 03-20-2014, 06:37 PM
Define trashed. Sometimes all hubs need is good disassembly clean and lube.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 7 Old 03-20-2014, 06:38 PM
ZMANN's Avatar
Quoted: 1911 Post(s)
the only auto's I know of are OEM
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #4 of 7 Old 03-20-2014, 08:23 PM Thread Starter
one of the hubs is broken and missing the o-ring. I can try locking them to make sure the 4 wheel drive works. If it does they I guess the vacuum circuit is bad. I just didn't know if it is better to change to full manual hubs.
post #5 of 7 Old 03-20-2014, 09:41 PM
I thought mine were broken, a quick tear down and lube proved otherwise. O-rings aren't hard to find, I'd start at NAPA.
On the 03 and up, if the air goes dashboard vent to windshield vent when 4HI is selected, then the vacuum system has a leak. However, even in this condition, selecting LOCK on the hubs should get front axle engagement.
Lock the hubs then try to twist the drive shaft while it's in park. That's how I find out if my hubs have unlocked after I have manually locked them. I don't trust the vacuum system all of the time. Sometimes I have to rock the u-joint on the passenger side when that hub hangs up.
Karls03 is offline
post #6 of 7 Old 03-21-2014, 02:58 AM
700xxmaniac's Avatar
I've turn stock hubs and warn premiums into metal shavings, I now have mile maker hubs.. Got them off xdp they have lasted two years of abuse, like mud pits, truck pulls, hooking chains on pavement ( how I killed the other hubs), and just heavy trails and powerlines!
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #7 of 7 Old 03-29-2014, 02:45 PM Thread Starter
Thanks everyone for their help. You won't believe what the problem was. I replaced one of the hubs, no problem. The 4 wheel drive still didn't work I checked all the vacuum circuits they were ok. It turns out the fittings on the knuckles were rusted shut. I replaced the 2 hoses and added brass fittings and the 4 wheel drive works great!!!!
The Following User Says Thank You to Mustang Al For This Useful Post:
Karls03 (03-29-2014)
