Rear Add-A-Leaf Removal - Ford Powerstroke Diesel Forum
post #1 of 21 Old 03-19-2014, 03:51 PM Thread Starter
POWERCHOKER
Dantron's Avatar
I'm looking to lower the rear end of my truck about 1/2 an inch. I have a Pro Comp 6 inch lift, which I believe used an add-a-leaf for the rear suspension height.
Would removing a single leaf spring in the rear result in the change I'm looking for? If so, which one of these leafs should I remove?
ID:	259809   Click image for larger version
ID:	259817   Click image for larger version
ID:	259825   Click image for larger version
Dantron is offline
post #2 of 21 Old 03-19-2014, 04:32 PM
SS4Matt's Avatar
The very bottom leaf that goes pretty much strait is the "add a leaf" that's part of the kit. Removing it may lower your truck more than the 1/2" you're after....You may want to consider swapping the block out for a smaller one.
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #3 of 21 Old 03-20-2014, 05:10 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Oh I see. Thanks!
Dantron is offline
post #4 of 21 Old 03-20-2014, 05:26 AM
ZMANN's Avatar
Quoted: 1903 Post(s)
thats is the overload leaf it makes the rest of the inverted arch lay down on it under compression and it caries the load
the thickness of that spring is the minimum your truck will drop when removed ( like Matt mentioned ) also make sure you have enough threads on the ubolt to do accommodate the missing spring thickness ( supposed to use new u bolts )
but you will also loose some load capacity if it was included in the OEM rating and it will ride a little different
and honestly that looks like an oem leaf pack all 5 leafs, they probably used a block an add a leaf wouldn't add 6"
ps that that bottom leaf is part of the pack and has a through pin so you need to clamp the pack remove the pin , remove leaf,re pin usually requires a new pin
might be easier to raise the front the 1/2 inch IMHO
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #5 of 21 Old 03-20-2014, 07:29 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Yeah the guy at 4 Wheel Parts wasn't exactly sure what my lift components were off the top of his head. There very well could have been no add-a-leaf at all. I tried ordering a 1 inch coil spacer to raise the front, but he said I wasn't able to "stack" kits like that for I would need new shocks, tract bars, etc. I'm beginning to doubt his knowledge on what will work or not. I'm thinking about ordering something from PMF myself. The only thing stopping me is that 4 Wheel Parts will only install what they sell and PMF is not one of their vendors.
Dantron is offline
post #6 of 21 Old 03-20-2014, 06:44 PM
Are you sure that's a 6" lift? Most 6" lifts use a second block and the add-a-leaf. Maybe it was a bad camera angle, but that only looked like one block. When we lowered my friend's F-350 from 8 to 4, all we had to do out back was remove the extra block. His add-a-leaf from the 8" lift and the factory block were a good match for the front 4" lift springs.
I'm thinking that second spring up from the over load spring is an add-a-leaf. It doesn't exactly have the same weathering and it doesn't conform to the other springs. I had an add-a-leaf and it looked much like this spring does.
Finally, removing a leaf doesn't necessarily require a new pin. The existing pin can be shortened and new threads cut into it for reassembly. Not saying you should remove anything, but if you did.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 21 Old 03-21-2014, 02:38 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Karl's right, the third spring down is the add. The bottom is factory, the overload. Sure you can remove it, only real downside is axle starts to move backwards as you adjust ride height like that (in wheel well). If you can remove blocks that is the best way to drop down.
Also these guys correct you don't get 6" from an add-a-leaf you get 1.5-2" so if your truck is probably 4" lift in rear from the leaf and it looks like you have 4" block.
1/2" adjustment? I think removing the leaf or changing the block going to do more then that. If you never tow you could remove that overload spring and that would drop you the thickness of it.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 21 Old 03-21-2014, 07:41 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Yes, that is exactly right. I went under the truck to measure the block and it was indeed 4 inches. I happen to have another set of blocks from a previous leveling kit which measures just under 5 inches, so maybe the excess drop from removing the add-a-leaf could be corrected by installing the slightly larger block.
This method feels uncertain and overly complicated for the result I want. I should probably get in touch with PMF suspension and see what they suggest. I'm open to lifting the front end 1/2 an inch to get my desired stance. Even though it would have been convenient for 4 Wheel Parts to fix up the stance while they installed my rear traction bars which I ordered through them, I can always find another shop to install whatever method I choose to do. I would do it myself but I don't have the necessary workspace or equipment to get my truck up off the ground. Thanks to everyone for the input...
Dantron is offline
post #9 of 21 Old 03-21-2014, 09:34 AM
I would keep more springs instead of going to less springs and taller block. My vote is still get 4-6 50 lb bags of sand in the bed to get desired ride height and improved ride. That will give you time to figure out what exactly you want instead of changing it up all the time. It would save big time and only cost $20
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #10 of 21 Old 03-22-2014, 10:47 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Brett
You just gave me an idea..
What if I put 200-300 lbs of diesel fuel separeted in multiple sealed canisters and position them between front of the bed and the center mounted spare tire?
That way I could add extra weight as well as keep fuel reserves in my bed...
Dantron is offline
