Controlling Air Bags With On Board Air - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ZMANN
post #1 of 3 Old 03-18-2014, 11:08 AM Thread Starter
To Many Projects
Twinjracing's Avatar
Quoted: 14 Post(s)
The Question is I'm looking at adding Train horns and would like to be able to controil my airbags also looked on airlifts page and can't find anything to do this. What is the best way to do this Thanks JJ
17 F250 XLT CC LB SRW 4X4, Truxedo Lo Pro Cover, Spray In Bedliner, Airlift Bags, And Cobra 29LX
E99 F250 Ext LB 4X4 Terminator HPOP, Rosewood Stage 160/80, T4 Billet S366 66/74/1.10, NLTD Tunes, Custom Traction Bars, Custom Winch Bumper
71 Cutlass Supreme Dragcar, 66 GTO, And 72 Vista Cruiser
JJ
Twinjracing is offline
post #2 of 3 Old 03-18-2014, 11:26 AM
ZMANN's Avatar
Quoted: 1665 Post(s)
the best way is to not intermingle your onboard air and your bags IMHO
the only way I would do it is if you have a shrader valve and hose and manually adjust
otherwise you get an overly complicated setup with dump valves /solenoids wires /guages/hoses/ ETC and x2 if u want side to side control
when you could have bought a trouble free wireless compressor/controller and have 0 issues IMHO
Heavy_GD likes this.
We Miss you Ronnie
ZMANN is online now
post #3 of 3 Old 03-19-2014, 05:06 PM
Quoted: 27 Post(s)
One way to do this is as follows -
- Install a storage tank with pressure switch. 3-5 gallon or so should be fine. One with multiple large (1/2" minimum on the largest) openings would be best.
- Plumb and wire the compressor to fill the tank based on the pressure switch.
- Plumb each bag (or group of bags depending on your setup) through a solenoid valve connected to the tank. Place a T fitting inline between each valve and the bag. These valves need to be wired to your inflate switch in the cab.
- Install a solenoid valve in the open side of each T installed in the last step and wire to the deflate switch in the cab.
- In the largest opening in the tank, install a fast opening, or dump, solenoid valve.
- Plumb your horn to the valve using the least amount of tubing and at least 1/2" diameter if possible. The intention is to get the most air to the horn as fast as possible. A larger tank will allow the horn to sound longer, louder.
- Wire this solenoid to the horn switch of your choice.
- Have fun scaring the pants off of people with your new horn.
This is based on a set of generic conditions. Your components may or may not function properly with this, but I encourage you to give it a try and make it work. Hope this is what you were looking for.
Sterling6.7 is offline
