Issues with ReadyLift kit on 2013 F250 - leans 1" to the left & pulls right driving - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-10-2014, 02:58 PM Thread Starter
Quoted: 5 Post(s)
Had my local and trusted mechanic (he put a 6" lift on my 2011 F-150) install a ReadyLift Stage III kit with some Bilstein shocks on my 2013 F-250 4x4 6.7L. Here is the link to the kit:
2011-2013 Ford Super Duty F250 Stage 3 SST Lift Kit
It was not noticeable at first, but now 3 months later, my truck "leans" 1" to the left. I measured the height of my wheels wells on each side of the truck to confirm this. You can see it from a close distance when the truck is on a flat, even surface. I also noticed I seem to pull to the right a bit on the road.
I'm a total suspension novice and have no desire or time really to get under there and install or tweak anything myself. I'm willing to add any extra parts or have it re-installed by someone else if something is not right. I asked him about the leaning and he said that was normal on Super Dutys with leveling or lift kits. I forgot to look at his 2010 with a 6" lift to see if that held true. I did not ask him about the steering yet.
Any insight to the problem? Thanks.
HOOPSboy is offline
post #2 of 17 Old 03-10-2014, 03:34 PM
Steel Arizona's Avatar
I wouldn't call that normal. I've seen them ride lower in the back after time, but not to one side or the other. Is it level front and back or is it sinking in one corner?
E99 F-250SD PSD ZF6 EC LB 4x4
Running: S&B CAI, 4" Turbo-Back to 5" Single Stack, Leveling Kit, In-Dash Navi, 35" Nitto M/T's, 203*, Oil Bypass, Coolant Bypass
On Deck: Tunes, Turbo & New Sticks?
Steel Arizona is offline
post #3 of 17 Old 03-10-2014, 03:48 PM Thread Starter
Quoted: 5 Post(s)
It is level front and back. I measured all 4 wheel wells and both wheel wells on the left sit 1" lower.
HOOPSboy is offline
post #4 of 17 Old 03-11-2014, 03:50 AM
boatpilot's Avatar
Actually it is normal...think about it, fuel tank, def tank etc on drivers side so it's gonna lean a little that way. Even stock trucks suffer this fate. If it bothers you ford sells a shim/spacer that you can install to correct the drivers side squat.
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
post #5 of 17 Old 03-11-2014, 07:07 AM
I have witnessed this myself before with aftermarket lifts! But it was on the pass side. As far as ford having a spacer, I dont know. I did get said coil replaced under warrenty. Even if it was cause of gas tank,def....it wouldn't be up front, all that is damn near over rear tire. Op u might just have a freak of coil spring. I dont know what else it could be, I'd say that it has nothing to do with lift. Also as far as the "pull"....what tires ya got? Toyo mt pull right.
jayz is offline
post #6 of 17 Old 03-11-2014, 07:33 AM
boatpilot's Avatar
You're wrong...it affects the front as well as the rear. Go put a tape on a stock truck and you will see.
Carli front lift coils are taller on the driver side to accommodate for this as it is a known occurrence on these trucks.
2012 F350 KR
post #7 of 17 Old 03-11-2014, 07:36 AM
I have put a tape to these trucks more then once (every corner before I lift them)...new n old and NEVER found this a problem other then what I stated!
jayz is offline
post #8 of 17 Old 03-11-2014, 08:33 AM
OCVeloMan's Avatar
Quoted: 151 Post(s)
Garage
Go measure brand new Super Duties on the lot, you'll find they all sit .5"-.75" down on the driver's side. That's will very little fuel as dealerships don't keep tanks full.
OCVeloMan is offline
post #9 of 17 Old 03-11-2014, 09:23 AM
I did on my 14, it was only about 1/8th off...from lot to home before I lifted it. I've never noticed it on any of my trucks or others I've lifted. I know you guys have seen WAY more then me though lol
jayz is offline
post #10 of 17 Old 03-11-2014, 12:25 PM
Quoted: 6 Post(s)
I will confirm. My stock 2013 Lariat CC/SB with plow prep package sits about .75" lower on the front drivers side vs. passenger. The rear driver and passenger sides are exactly the same (and match the front drivers side).
-Bryce
2013 F-250 Lariat CC/SB 6.7 Powerstroke
Ready Lift Stage 3TP
IDP Custom Tuned
Rancho RS9000XL Shocks
Rancho Dual Steering Stabilizers
Titan 50 gal fuel tank
bleppek is offline
