4" rear block now have vibration - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 03-09-2014, 07:48 PM Thread Starter
79 toy's Avatar
I installed ready lift 4" rear blocks on my 2002 crew cab short bed 4x4 and now my driveshaft vibrates. I tried to shim my carrier bearing. Started with 1/4" shim and kept adding and it never went away. I added up to 1 1/4" of shims and still have this problem. I'm just looking for some advice any help would be great and thank you.
RedneckYankee likes this.
79 toy is offline
post #2 of 20 Old 03-09-2014, 07:55 PM Thread Starter
79 toy's Avatar
The 4" blocks also have a taper to them.
79 toy is offline
post #3 of 20 Old 03-10-2014, 04:18 AM
schlutzer's Avatar
Quoted: 18 Post(s)
What does your pinion angle look like?
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 20 Old 03-10-2014, 04:53 AM
Shadowfax's Avatar
Quoted: 9 Post(s)
pinion angle. You probably need to shim it.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
post #5 of 20 Old 03-10-2014, 05:18 AM
Quoted: 3 Post(s)
Did you bother reading the post?
To the OP, how much total lift do you have? Was it stock before the 4" block? Jack up the rear and spin the rear drive shaft by hand. Check for loose straps, worn u joints, pinion seal, pinion tabs that hold the u joint, and your carrier bearing
Also, when does the truck vibrate?
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #6 of 20 Old 03-10-2014, 05:22 AM
schlutzer's Avatar
Quoted: 18 Post(s)
The OP shimmed his carrier bearing, not his leaf springs as shadowfax and myself are both asking about.
post #7 of 20 Old 03-10-2014, 05:27 AM
Quoted: 3 Post(s)
Shim his leaf springs? Who does that.....
He has a tapered block if that's what you're referring to.
01 Ex 7.3l Limited
06 headlights
post #8 of 20 Old 03-10-2014, 05:28 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Doesn't mean the taper is right, shimming the leaf springs is done every single day... easiest way to set pinion angle unless you want to cut off your perches and move them like I have.
Tapered lift blocks do the EXACT same thing, and you can also buy them in different degrees, just like pinion angle shims
post #9 of 20 Old 03-10-2014, 05:33 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I asked him what it was, and Shadowfax suggested it as a possibility.
Especially since the OP seems to have only focused on the carrier bearing it is pretty logical to me to query about the other side of the equation.
post #10 of 20 Old 03-10-2014, 06:27 AM
Problem is, it's tapered! Need a flat 4" block on a ccsb!
jayz is offline
