Help deciding with 2.5 level or 4 inch lift - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-06-2014, 03:26 PM Thread Starter
lowrider284's Avatar
I've been researching leveling kits and lifts since I bought my truck almost 2 years ago but have yet to pull the trigger on anything. I'm really torn between a 2.5 Icon leveling coils with front/rear bilstein 5100s, 4" blocks and adjustable track bar or the Pure Performance 4 inch x-factor system with bilstein 5100s. My truck is strictly used on the road and I want something that rides a little better without spending thousands of dollars on a kit considering I'm looking at another $2300-2500 on wheels and tires (20x9 with 35" ATs). I hear great stuff about Icon and Pure both but I figured if I'm going for the 2.5 why not go to a 4 inch for a few hundred extra. But then most people are saying to throw on a dual steering stabilizer and possibly look into the triple threat system with spring packs instead of blocks so the Pure would be almost $1900 at this point. Would the spring packs really be justified? Just looking for opinions for a street-driven truck that does no towing at all. Do I need the dual steering stabilizer for both the 2.5 level/lift or 4 inch. All in all I'm looking to get away with the best valued kit/option for my purpose.Thanks in advance.
lowrider284 is offline
post #2 of 11 Old 03-07-2014, 05:59 AM
I had your same truck but a 07. I had a Readylift level kit for the front and F350 blocks for the rear. Truck rode like stock and I have always had a 24ft enclosed I pull that can get heavy when loaded. I loved the look, ride height and got compliments non stop. I went with 20x10's and 35's and only had to do minor trimming and zip tie the fender linings back a hair.
SWIFT is offline
post #3 of 11 Old 03-07-2014, 07:25 AM
I run a 4" triple threat. Love th ride. It's worth it to upgrade to the mini packs. I also went with 5100s. They are a little stiff but the ride is better than stock.
Pure offers a 10% discount for forum members or contact a forum sponsor for their price.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
The Following User Says Thank You to rustyshakelford For This Useful Post:
lowrider284 (03-07-2014)
post #4 of 11 Old 03-07-2014, 01:11 PM Thread Starter
Brett
Did you go with a dual steering stabilizer?
post #5 of 11 Old 03-07-2014, 02:23 PM
No. Haven't really needed it. If I do, it'll prolly be a carli single steering stabilizer though. I get a little bump steer but I only have 8k on the truck and 4k on the lift so everything is still very tight.
Brett
post #6 of 11 Old 03-11-2014, 08:00 AM
DSTRBD's Avatar
I suggest Icons Stage I 2.5" kit over the coils and Bilsteins. You will have a much smoother, better handling ride this way. It is definitely worth the extra cost.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #7 of 11 Old 03-11-2014, 09:54 AM Thread Starter
I actually ended up pulling the trigger on the Icon stage 1 with upgraded Icon track bar both brand new never used from a Org member and bought some ReadyLift 4" blocks off Amazon to go with it. Pretty excited to put the kit on next week. Will post pics and will review. Thanks guys
post #8 of 11 Old 03-12-2014, 02:49 AM Thread Starter
The Readylift blocks have a taper? Are they supposed to?
post #9 of 11 Old 03-12-2014, 03:07 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Most rear blocks have a slight taper. As do the oems
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
The Following User Says Thank You to Dave For This Useful Post:
lowrider284 (03-12-2014)
post #10 of 11 Old 03-12-2014, 07:58 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Just remember this: if you want to improve the ride more tire sidewall enhances the ride. A 18" wheel is going to ride much better then a 20". The more sidewall you have the better.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
