Minimizing axle wrap without traction bars - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-05-2014, 02:27 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Okay so I hate lift blocks, I guess I work the truck too hard in the fields and kept breaking leafs.
Like so.... yes yes stacked blocks but almost all the cheaper lift kits require you to stack blocks now. That's what many many people run with no issue, this was a Rough Country lift.
Garbage, hated that setup from the day I bought the truck but I had other issues to deal with first.
Then a few months ago I bought some used Superlift 5" springs that were less than a year old, and PMF's 4.5" flip kit. Put all that on with a 4 shim and a plate to relocated the axle back 1.5".
Like so.
This was much better but I had two problems, an increase in axle wrap and since I have a ceramic clutch it was very annoying, and then two days ago the center pin broke on the drivers leaf. The combination of the relocation plate and the shim is no good, again a lightly driven street truck would probably have no problem, I was pulling on a stuck tractor digging through frozen clay.
So now I have gone super beefy...
3/8's top plates, 3/4" U bolts, 8" long spring perches, and I drilled the springs out to accept a 1/2" center pin bolt instead of the 3/8's bolt the Superlift springs had.
First drive was a huge improvement, no more hop on takeoff, way smoother shifting, and much more solid feeling ( although that's probably in my head).
I will say anybody running Superlift 01-179 springs, ditch the bushings and put some poly ones in, the Superlift ones are useless.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
The Following 3 Users Say Thank You to schlutzer For This Useful Post:
Corey@CNCFAB (03-05-2014), Karls03 (03-06-2014), mhatlen (03-08-2014)
post #2 of 3 Old 03-08-2014, 11:34 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 443 Post(s)
Garage
You know that's taking the bull by the horns. I can't stand looking at a truck with traction bars running down to the rear end. Looks like $hit, doesn't matter how you paint it !!!
Four link systems that you see the lower link mounting to the frame under the door handles look as bad as traction bars as far as I see it. Looks great guy a well worth the effort job.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #3 of 3 Old 03-08-2014, 11:43 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Thanks man. I have a feeling it'll be inevitable when I do the power upgrades that I'm collecting parts for that I will end up with traction bars but I'm going to mount them as tall as I can on the axle with a hangar mount on the front side.
They will be much less visible, and more importantly as high as possible off the ground.
But for anybody staying near stock power a longer spring perch definitely makes a noticeable difference in the wrap.
