noob help, wheel bearing? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-05-2014, 09:01 AM Thread Starter
i've never replaced a wheel bearing in a big truck before so as my truck started to make the wheel bearing noise i went to auto zone to buy a new wheel bearing and was expecting to see the usual hub assembly like in a little fwd car or something, instead they showed me a pic like this
http://www.carid.com/images/wp/skf/w01331702944skf.jpg
is this what im looking for and would i have to get them pressed in? how much would a hub assembly be compared to getting these pressed in, i know a shop that charges $40 to press things in, thanks ahead of time.
JMoore17 is offline
post #2 of 11 Old 03-05-2014, 09:14 AM Thread Starter
seems like it would be over 5 bucks, yes/no?
http://www.autozone.com/autozone/par.../N-jkdesZ8oxk8
JMoore17 is offline
post #3 of 11 Old 03-11-2014, 12:53 PM Thread Starter
Any help? Thanks.
JMoore17 is offline
post #4 of 11 Old 03-11-2014, 01:00 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
What you driving? Year?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 11 Old 03-11-2014, 08:14 PM Thread Starter
03 4X4 6.0
JMoore17 is offline
post #6 of 11 Old 03-11-2014, 08:17 PM Thread Starter
basically the bearing itself for 4 bucks that i would put into my hub assembly or buy the hub assembly for 100+ bucks? autozone employees are no help so what do you guys say?
JMoore17 is offline
post #7 of 11 Old 03-11-2014, 08:41 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Front wheel? If so its a whole hub bearing assembly. The above pic would be correct for a 2wd
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 11 Old 03-12-2014, 03:37 AM Thread Starter
ok cool thanks, and when they say course or fine thread they're talking about my studs? or wrong again?
JMoore17 is offline
post #9 of 11 Old 03-12-2014, 05:59 AM
Quoted: 3 Post(s)
Correct
10char
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #10 of 11 Old 03-12-2014, 06:43 AM
ZMANN's Avatar
Quoted: 1357 Post(s)
most like Me suggest only using Timken the OEM brand
and shop hard autozone for my 06 is over 600 bucks but shop a little and i can find it for 350 .00 yours should be cheaper but still shop around amazon has the best price on mine most times
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
bigred3297 (03-12-2014)
