Is there an FAQ or informational thread for lifting? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-02-2014, 08:25 AM Thread Starter
Quoted: 5 Post(s)
This is totally new to me. I have an '07 FX4 that I'd like to put a 2.5" or 4" lift on. I have stock 20" wheels with 275/65s. When it comes time to change the tires I plan on going slightly bigger but nothing too big. Also looking for comparison pics with stock next to 2.5" and 4" lifted trucks and pros/cons.
Thanks in advance.
P7M8 is offline
post #2 of 9 Old 03-03-2014, 05:00 AM
Search button man.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #3 of 9 Old 03-03-2014, 07:30 AM Thread Starter
Quoted: 5 Post(s)
Yeah, already tried that. Too many generic topics.
'07 CC/SB FX4
XDP Coolant Filter
Blue Spring Mod
High Idle
4" Turbo Back Exhaust
200* Mishimoto T-Stat
EGR Delete
Leveling Kit
Billstein 5100s
Pro Comp Dual Steering Stabilizer
P7M8 is offline
post #4 of 9 Old 03-09-2014, 07:24 AM
Q-DawgVFR's Avatar
Wheel, Tire, Lift Combos, post em up, show me what your workin with lol.
The above link might help.
You looking to stay stock other than bigger tires?
You doing the lift for looks or to change ride quality? Do you still need full payload?
You will probably get more reply hits once you start asking more specific questions and do a bit of reading. Yes there are a lot of general threads, but you are seeking general information, so you will get some answers if you do search and start picking through them. Most of the threads you will notice common themes emerge, depending on what your goals are. I only had to read through about 4 threads to zero in on the direction I was likely to go. Yes it takes time, but I've given you some information to get you rolling.......
You can also search my thread if it helps: Small lift required for 2014 F350 to run 20" wheels on 35's? Please post your pics.
I was starting in a similar place: unfamiliar with all of the choices out there, and not sure what to do. I did a LOT of my own reading / research and chatting with folks on the board here. In the end I think I will order up the 4.5" Carli Back Country 2.0 kit as I want to spend the money once and have a quality kit with better than stock ride.
Down-sizing to a 18" wheel will give you best ride quality everyone tells me. I'm still going to be stubborn and run a 20" for looks, but choosing the 4.5" kit so I can put a bit more tire on it.
If you PM me your email addy, I have made a VERY nerdy Excel sheet with breakdown of all my lift and wheel considerations. It might help you in your quest.
Any other specific questions you have, I am sure people will chime in. I am pretty new to the board but I am really impressed with how helpful everyone is on here.
Q-DawgVFR is offline
post #5 of 9 Old 03-10-2014, 09:07 PM Thread Starter
Quoted: 5 Post(s)
Q-Dawg - Thanks for your response. I figured I'd ask for the FAQ since I didn't see a sticky and I'm sure these questions have been asked before.
I want both a bolder look and a little more ground clearance. I live in the New Orleans area. Never know when you have to leave the road to get around stuff as I learned navigating here after Hurricane Katrina. I wouldn't want to loose too much of the ride quality. Not that it's great with pothole laden streets anyway.
Not sure how much bigger (wider) I can go on a stock 20"x 8" wheel. Any idea? I don't need full payload either. Not sure how funny the truck would look if I went 4" up and stayed with the stock tire size.
Carli appears somewhat expensive compared to some of the other kits. I realize you get what you pay for. Not looking to break the bank.
I'll check out your links and PM you the email. Any help would be greatly appreciated.
P7M8 is offline
post #6 of 9 Old 03-11-2014, 06:42 AM
Q-DawgVFR's Avatar
Few kits are likely to improve ride quality unless you replace rear blocks with different springs, or go with a Carli and their minipack (overload and block alternative)
You get what you pay for, as you stated, so I guess you will have to decide if cost and bigger tires is more important than ride quality.
Bigger tires should help a little bit, but going from 20's and downsize to 18's/larger tires will give the most benefit in ride quality other than doing leaf spring upgrades, according to everyone I have talked to that has done it.
BDS seems to be a popular choice for the budget minded. They are a popular choice here where I live, and I was very tempted to do their 4" control arm conversion lift with rear leaf upgrade. But by the time you option up the BDS 4" kit with some nicer shocks, it was getting pretty close to Carli prices. I decided on Carli after seeing how good their customer service is and watching product demos on youtube.
post #7 of 9 Old 03-12-2014, 08:49 AM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
Here's a couple good resources PACKED with info:
Carli Suspension - Official Thread
Wheel and tire combos with our lifts:
Carli tire, wheel combos and pics
OCVeloMan is offline
post #8 of 9 Old 03-12-2014, 09:07 AM
Carli and pure are awesome.
That said, I went with pure performance and love it. It rides better than stock and looks great. I upgraded to the triple threat with SS brake lines and mini packs. Easy install and very very happy.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #9 of 9 Old 03-17-2014, 10:19 PM
knuckledragger5's Avatar
Quoted: 9 Post(s)
After I recover from my bulletproofing escapade ill be going with the Carli commuter 2.0. Awesome set up you get leveled off, can clear the 35's nicely and your putting quality equipment where its most important. if I can swing it id like to do the pin top kings but money isnt growing on trees..yet. As stated above check the Carli thread they have photos and links to videos of the guys running their rigs from anza borrego to baja california... very impressive.
2016 Platinum Tri Coat CCSB F250 Lariat Ultimate, FX4, Factory 20's with the TOYO ATII's
damn trucks loaded, seriously! it has heated rear seats! WTF!
***SOLD***
06 F250 CCLB Lariat FX4
por vida
knuckledragger5 is offline
