Wheel on driver side further forward after 3" level... Help!!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-26-2014, 06:53 PM Thread Starter
Ok so I recently put a 3 inch mini spring pack lift on the front of my 2003 f250 my truck is full leaf springs and I used the bushing type spacers for the track bar bracket. I took the truck to get aligned and they tell me they cannot align it because my pass side wheel is further forward than driver side... Sure enough I measured and the driver side wheel is maybe 3/4 inch further towards the rear of the truck than on the other side when both pointed perfectly strIght forward. My steering wheel is also out of alignment but I assumed that was unrelated. What could cause this? When crawling under the truck the axle looks almost slightly turned toward the drivers side but it could be my imagination. Truck has a clear history with no accidents. I went ahead and ordered an adjustable track bar but idk if that could cause this?
7.3mason is offline
post #2 of 14 Old 02-26-2014, 07:41 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I'm guessing one of the spring packs are in backwards
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
The Following User Says Thank You to mhatlen For This Useful Post:
Karls03 (02-26-2014)
post #3 of 14 Old 02-26-2014, 08:11 PM Thread Starter
Backwards? There is no backwards they are symmetrical
7.3mason is offline
post #4 of 14 Old 02-26-2014, 08:31 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Did you measure eyelets to spring pins? Gotta be a dimension that's off ???
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #5 of 14 Old 02-26-2014, 08:41 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Are you certain the spring pins are in the axle properly? Did you measure your old spring packs?
Strange I agree but something is off. The track bar is not it that will cause a issue only centering axle left to right.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #6 of 14 Old 02-26-2014, 11:46 PM
I think he meant the leaf spring itself could have been put in backwards.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 14 Old 02-27-2014, 12:40 AM Thread Starter
The springs do not get removed during installation they were retained in factory locations
7.3mason is offline
post #8 of 14 Old 02-27-2014, 01:51 AM Thread Starter
Where is the axle centering pin? I actually had a shop install the kit for me but they are about an hour drive away. There where no spring packs before. This is the donahoe type kit that installs 4-5 shorter leafs under the actual leaf spring and are centered with a center bolt
7.3mason is offline
post #9 of 14 Old 02-27-2014, 09:48 AM
layson's Avatar
Quoted: 82 Post(s)
I would call up that shop and tell them what the alignment shop said. Tell them that you verified their measurement and when can I take my truck back to them to figure out what is wrong with their install...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
The Following User Says Thank You to layson For This Useful Post:
Karls03 (02-27-2014)
post #10 of 14 Old 02-27-2014, 09:59 AM
We removed the front springs when I did an add a leaf years ago. That is why I suggested spring may have been flipped end for end.
Karls03 is offline
