How to idnetify leaf springs? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-25-2014, 09:53 AM Thread Starter
Quoted: 3 Post(s)
Long story short I bought a used 2001 F-350 7.3 yesterday. The previous owner did not know the brand of lift. The front bushing on the front leaf springs are shot. How do I identify the brand of springs so I know what bushings to order? Or will most use the OEM ones?
Thanks (I'm new to this truck but a long time hobbyist mechanic)
r33pwrd is offline
post #2 of 8 Old 02-25-2014, 11:57 AM
Post a pic if you can. Perhaps someone can recognise them for you.
sw99 is offline
post #3 of 8 Old 02-25-2014, 01:46 PM Thread Starter
Quoted: 3 Post(s)
Here you go. thanks
ID:	248713   Click image for larger version
ID:	248721   Click image for larger version
ID:	248729   Click image for larger version
ID:	248737   Click image for larger version
r33pwrd is offline
post #4 of 8 Old 02-25-2014, 02:03 PM
huck2080's Avatar
look like stock springs with extra leaves added to it
huck2080 is offline
post #5 of 8 Old 02-25-2014, 02:39 PM Thread Starter
Quoted: 3 Post(s)
Thank you! Would you recommend the energy suspensions bushings or just getting the OEM ones?
r33pwrd is offline
post #6 of 8 Old 02-26-2014, 05:03 AM
Quoted: 3 Post(s)
I recommend getting new springs. You can get a set of brand new OEM's for $300 or a new set of procomps for $150-$200.
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #7 of 8 Old 02-26-2014, 07:13 AM Thread Starter
Quoted: 3 Post(s)
great idea! I never thought the springs would be as cheap as they are. So I will order new front leafs first (as they are the issue) and than do the rears once I recover from buying the truck.
I guess the only thing I am not sure of is what height springs I need to order? Procomp offers 2, 4 and 6.5" ? I'm guessing at 4"? any way to measure? The truck has 35's and they don't rub at all.
r33pwrd is offline
post #8 of 8 Old 02-26-2014, 07:26 AM
Quoted: 3 Post(s)
Measure from the top of the axle tube (next to the spring perch) to the bottom of the frame (next to the bumpstop). Off the top of my head, a 4" lift will produce a measurement of 12"-13".
I'd guess that you're at a 2" lift and will measure about 10" using the guidance above. If this is so, I'd go with the x-code factory springs over the procomp 2" springs. The oem is said to ride better but I have no experience with either. I do know that OEM will be better quality and will last you longer without sagging
01 Ex 7.3l Limited
06 headlights
