Lift question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-23-2014, 06:30 PM Thread Starter
Jshak07's Avatar
Lift question
I have a leveling kit consisting of a mini spring pack in the front, and (2) 2" blocks in the rear.
How much lift can I add to this without having to extend my driveshaft and what not? I want to get some new rims with a negative offset to give it the stance look, but without lifting it, my front tires will rub the fender flares.
Thanks
ID:	247881   Click image for larger version
ID:	247889   Click image for larger version
Jshak07 is offline
post #2 of 13 Old 02-23-2014, 06:52 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 443 Post(s)
Garage
You can lift it 4" without having to use of drop down bracket. Driveline is good for 8" or so.
Basically 6" is when you need to do lots of mods to get geometry back on line.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 13 Old 02-23-2014, 07:06 PM Thread Starter
Jshak07's Avatar
http://www.summitracing.com/parts/ex...350-super-duty
Could I add this kit and be ok, or would I be better off removing the mini spring pack up front and just going with a 4" suspension lift?
Jshak07 is offline
post #4 of 13 Old 02-23-2014, 07:12 PM
ZMANN's Avatar
Quoted: 1343 Post(s)
you never mention the year but your user name has 07
gets confusing
but We can see by the front leaf springs your not an 07
We Miss you Ronnie
ZMANN is online now
post #5 of 13 Old 02-23-2014, 07:15 PM
ZMANN's Avatar
ps the summit link you provided is for a coil spring truck like an 07
We Miss you Ronnie
ZMANN is online now
post #6 of 13 Old 02-23-2014, 07:15 PM Thread Starter
Jshak07's Avatar
Sorry. Its an 03. I thought I updated my signature
Jshak07 is offline
post #7 of 13 Old 02-23-2014, 07:19 PM
mhatlen's Avatar
Quoted: 443 Post(s)
Garage
Nope but i saw the all chrome front bumper and leafs.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #8 of 13 Old 02-23-2014, 07:24 PM
mhatlen's Avatar
Quoted: 443 Post(s)
Garage
Scott knows those lifts better than I do. He will set you right.
Hey I did get new doorstipping for my truck and no more wind whistling. Just the uppers that take the sun. Going to do the surgical tubing trick you recommended. Gotta get on ebay myself.
Back to your lift. Not sure Zmann is going to like the front blocks.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #9 of 13 Old 02-23-2014, 07:27 PM Thread Starter
Jshak07's Avatar
Signature should be updated now. I posted the wrong link, I wasn't paying attention that the link wasn't leaf spring.
Could I just add additional leaf springs? Trying to save myself from having to pay the $1k for a 4" lift kit if possible.
2003 F350
6.0 Studded and deleted
18" XD's wrapped in 295/70 Nitto Trail Grapplers
Jshak07 is offline
post #10 of 13 Old 02-23-2014, 07:30 PM
ZMANN's Avatar
your signature never showed up not even pot #1
what exactly are you looking to achieve lift wise ?
We Miss you Ronnie
ZMANN is online now
